The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
telnet.firewall events
Creating your file...
Your file is ready
telnet.firewall.remove
- Severity
NOTICE
- Description
This message occurs when telnet is automatically removed from firewall policies during a revert operation from Data ONTAP® 9.0 to 8.3. Telnet is removed because it is an insecure protocol and it is by default disabled in Data ONTAP 9.0. In Data ONTAP 8.3, the presence of telnet in firewall policies after a revert operation enables telnet. To prevent this, the telnet firewall policy is removed during the operation.
- Corrective Action
Use the "system services firewall policy create" command to reenable telnet.
- Syslog Message
Telnet removed from firewall policy because of Data ONTAP revert operations. Telnet is now disabled.
- Parameters
(None).
