ONTAP EMS reference
vifmgr.portremoved events
vifmgr.portremoved EMS events occur when ONTAP encounters issues associated with ports being removed because they no longer exist.
vifmgr.portRemoved
Severity
NOTICE
This message occurs when a port is removed because it no longer exists.
Corrective Action
(None).
Syslog Message
Port %s on node %s has been removed because it no longer exists.
port (STRING): Name of the nonexistent port.
node (STRING): Name of the node on which the nonexistent port used to reside.
vifmgr.portRemoved.lifHomed
Severity
NOTICE
This message occurs when a logical interface's (LIF's) home port is updated because its previous home port has been removed from its broadcast domain.
Corrective Action
(None).
Syslog Message
Home port of LIF %s (Vserver %s), IP addr %s updated to node %s port %s from node %s port %s: port removed from broadcast domain.
vifName (STRING): Name of the LIF on which the home port is being updated.
vsrvId (STRING): ID of the virtual server on which the LIF resides.
vifIp (STRING): IP address of the LIF on which the home port is being updated.
toNode (STRING): Name of the node to which the LIF's home port is being updated.
toPort (STRING): Name of the port to which the LIF's home port is being updated.
fromNode (STRING): Name of the node from which the LIF's home port is being updated.
fromPort (STRING): Name of the port from which the LIF's home port is being updated.
vifmgr.portRemoved.lifMoved
Severity
NOTICE
This message occurs when a logical interface (LIF) is moved from a port that has been removed from its broadcast domain.
Corrective Action
(None).
Syslog Message
LIF %s (Vserver %s), IP addr %s moving to node %s port %s from node %s port %s: port removed from broadcast domain.
vifName (STRING): Name of the LIF that is being moved.
vifIp (STRING): IP address of the LIF that is being moved.
toNode (STRING): Name of the node to which the LIF is moving.
toPort (STRING): Name of the port to which the LIF is moving.
fromNode (STRING): Name of the node from which the LIF is moving.
fromPort (STRING): Name of the port from which the LIF is moving.
