vsdr.fpvolallpolicyonfpaggr events
Creating your file...
vsdr.FPVolAllPolicyOnFPAggr
- Severity
ALERT
- Description
This message occurs when source volume of an SVM disaster recovery (SVMDR) relationship having a volume tiering policy of "all" residing on FabricPool aggregate on the primary cluster is placed on a FabricPool aggregate at the destination cluster. SnapMirror® transfer will be slow and might cause recovery point objective(RPO) to be missed.
- Corrective Action
Either move the source volume of the SVMDR relationship from the FabricPool aggregate to a non-FabricPool aggregate at the primary cluster or modify the volume tiering policy of the source volume. To move the source volume, use the "volume move start -vserver <vserver-name> -volume <volume-name> -destination-aggregate <aggregate> command." To modify the volume tiering policy, use the "volume modify -volume <volume-name> -vserver <vserver-name> -tiering-policy <snapshot-only|none|auto>" command.
- Syslog Message
Source volume "%s" of the SVMDR relationship residing on a FabricPool aggregate having a tiering policy of "all" on the primary cluster is placed on FabricPool aggregate "%s" at the destination cluster.
- Parameters
source_volume_name (STRING): Name of the source volume on the FabricPool aggregate of the SVMDR relationship.
dest_aggr_name (STRING): Name of the destination FabricPool aggregate at the secondary cluster.
