ONTAP EMS reference
wafl.clone events
wafl.clone.no.basesnap
Severity
ERROR
This message alerts you about a missing clone flexible volume base Snapshot(tm) copy and strongly recommends that you take the clone flexible volume offline and destroy it.
Corrective Action
Take the clone flexible volume offline immediately. If you know that the clone does not contain any valuable data, you can safely destroy and re-create it.
Syslog Message
Base Snapshot copy for clone flexible volume %s on aggregate %s is missing. It is strongly recommended that you take the clone offline and destroy it. Failure to do so might lead to clone panic at any time.
clonename (STRING): Clone flexible volume name.
aggrname (STRING): Aggregate name.
wafl.clone.snapSpcGuar
Severity
INFORMATIONAL
This event is issued if an attempt is made to delete a snapshot in a clone volume that would require the space guarantee on the clone to exceed the available space in the aggregate. A clone volume initially shares one or more snapshots with its parent volume. This allows the space guarantee to be optimized, reducing the space requirement in the aggregate. If a shared snapshot is deleted then extra space is required in the aggregate to ensure the space guarantee for the volume can be enforced. If the freespace in the aggregate is too small to allow this then the snap delete is rejected.
Corrective Action
This state can be corrected by performing one or more of the following actions: o Change the space guarantee on the volume so that less space is required in the aggregate. o Free space in the aggregate by shrinking or removing volumes. o Add space to the aggregate, e.g. by adding disks.
Syslog Message
Snapshot '%s' in clone volume '%s%s%s' cannot be deleted, there is insufficient space in the aggregate to enforce the space guarantee (%s)
snap_name (STRING): The snapshot name
vol_name (STRING): The volume name
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
guarantee (STRING): The current guarantee
wafl.clone.snapsplit.nospace
Severity
NOTICE
This message occurs when there is not enough free space to complete a file clone split operation from the Snapshot(tm) copy. The clone file might become unreadable when the parent Snapshot copy is automatically deleted.
Corrective Action
Increase the space available to the volume by either adding disks or by freeing space in the volume to allow the split operation to continue.
Syslog Message
File clone split from Snapshot copy of '%s%s%s' cannot be completed due to lack of disk space.
name (STRING): Volume name.
volident (STRING): Uniquely identifies the volume in cases where the volume name itself is insufficient.
wafl.clone.split.start.vol.fenced
Severity
NOTICE
This event indicates that vol clone split start was called for a fenced volume after iron completion.
Corrective Action
(None).
Syslog Message
Volume clone split start called for fenced volume '%s%s%s'.
volname (STRING): Volume name
wafl.clone.unrecoverable
Severity
ALERT
This message occurs during boot when a clone is marked unrecoverable due to its missing base Snapshot(tm) copy.
Corrective Action
If you know that the clone does not contain any valuable data, you can safely destroy and re-create it. If it contains any valuable data, you can recover only the data which was written after the volume clone was created. Trying to access the data which was shared with the base snapshot (original data) will result in error.
Syslog Message
Base Snapshot copy for clone %s on aggregate %s is missing. Marking it unrecoverable.
clonename (STRING): Clone name.
