wafl.raid events
wafl.raid.cft.aggr.snapshot.missing
- Severity
ERROR
- Description
This message occurs during an aggregate transition workflow when an aggregate Snapshot® copy created in a 7-Mode environment is missing.
- Corrective Action
Return the disks to the 7-Mode environment, create the Snapshot copy for the aggregate, and then repeat the transition workflow.
- Syslog Message
Aggregate transition failed for aggregate %s due to unavailability of the 7-Mode aggregate snapshot.
- Parameters
aggrname (STRING): Name of the aggregate.
wafl.raid.incons.buf
- Severity
ERROR
- Description
This message occurs when the WAFL® kernel detects an inconsistent block on a disk. Access to the block is disabled until corrective action is taken.
- Corrective Action
Use the "volume file show-inode" command with the file ID and volume name information to find the file path. If the volume is inconsistent, run wafliron as soon as possible to clear the inconsistency. For a SnapMirror® target, rebuild from the source or resynchronize. If the block is in a Snapshot copy, delete the Snapshot copy. If the problem persists, contact NetApp technical support for more options.
- Syslog Message
WAFL inconsistent: bad block at VBN %llu (vvbn:%llu fbn:%llu level:%u) in %s inode (fileid:%s snapid:%u fixable:%d file_type:%d disk_flags:0x%x error:%u raid_set:%d) in volume %s%s%s%s.
- Parameters
vbn (LONGINT): Volume block number.
vvbn (LONGINT): Virtual block number.
fbn (LONGINT): File block number.
level (INT): Buffer level.
file_space (STRING): File space.
fileid (STRING): Identifying number for the suspect inode.
snapid (INT): Snapshot(tm) copy identifier: (0) - active file system (non-zero) - refers to Snapshot copy
fixable (INT): Boolean value indicating whether iron can repair this block.
type (INT): File type.
flags (LONGINT): Inode disk flags.
error (INT): Error on the block.
raid_set (INT): Boolean indicating whether RAID set the error.
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Uniquely identifies the volume in cases where the volume name itself is insufficient.
wafl.raid.incons.clear.error
- Severity
NOTICE
- Description
This message occurs when Data ONTAP® resets the error on a data block.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
Resetting error (%u) on data block in %s inode (fileid:%u snapid:%u fbn:%llu level:%u) in volume %s%s%s%s
- Parameters
error (INT): Error number that was reset.
inotype (STRING): Inode space (public or private).
fileid (INT): Identifying number for the inode.
volident (STRING): Uniquely identifies the volume when the volume name itself is insufficient.
wafl.raid.incons.dir.block
- Severity
ERROR
- Description
This message occurs when the WAFL® kernel detects an inconsistent directory block on disk, causing some entries on the directory not to appear. The message indicates the fileid and Snapshot(tm) copy of the block being accessed.
- Corrective Action
The volume has a bad directory block. Use the "volume file show-inode" command with the file ID and volume name information to find the file path. Recover the directory from a backup. For a SnapMirror® target, rebuild from the source or resynchronize. If the block is in a Snapshot copy, delete the Snapshot copy. Then contact NetApp technical support.
- Syslog Message
WAFL inconsistent: bad directory block in inode (fileid:%u snapid:%u) in volume %s%s%s%s.
- Parameters
fileid (INT): Identifying number for the suspect inode
snapid (INT): Snapshot copy identifier. (0) - active file system. (non-zero) - refers to Snapshot copy.
wafl.raid.incons.set.err.obj
- Severity
ALERT
- Description
This message occurs when Data ONTAP® marks a block in a capacity tier object with an error. This is useful for tracking movement of pseudobad and unverified blocks.
- Corrective Action
Contact Contact NetApp technical support..
- Syslog Message
Data block at VBN %llu tiered to capacity tier (objid %llu, slot %u, btuuid %s, seqno %llu) and marked with error (%u). Block previously had error (%u).
- Parameters
object_id (LONGINT): Object identifier.
slot (INT): Slot number.
btuuid (STRING): Buftree UUID.
seqno (LONGINT): Sequence number.
prev_error (INT): Previous error on the block.
wafl.raid.incons.set.error
- Severity
ALERT
- Description
This message occurs when Data ONTAP® marks an on-disk data block with an error. This is useful for tracking pseudo bad and unverified blocks.
- Corrective Action
- Syslog Message
Data block in %s inode (fileid: %u snapid: %u fbn: %llu level: %u) in volume %s%s%s%s marked with error (%u) by %s. Block previously had error (%u).
- Parameters
module (STRING): Module that is marking the block with the error.
wafl.raid.incons.snapmap
- Severity
NOTICE
- Description
This message occurs when WAFL detects a RAID inconsistency error in a snapmap block. The message recommends to delete the snapshot in which inconsistent snapmap resides.
- Corrective Action
(None).
- Syslog Message
Snapshot(snapid %u) block accounting metadata is corrupted. To avoid trapping unnecessary blocks in the snapshot, please delete the snapshot.
- Parameters
snapid (INT): Snapshot copy identifier: (0) - active file system (non-zero) - refers to Snapshot copy
wafl.raid.incons.snapmap.chk
- Severity
NOTICE
- Description
This message occurs when the WAFL® kernel detects a RAID inconsistency error in a Snapshot(tm) copy active map block, even though the block content passes a metadata check.
- Corrective Action
- Syslog Message
(None).
- Parameters
wafl.raid.incons.snapshot
- Severity
ERROR
- Description
This message occurs when WAFL® detects a RAID inconsistency error in a snapshot. The message indicates what snapshots have the inconsistent block, and how to recover from the inconsistency.
- Corrective Action
Delete the specified snapshot(s) during the next reboot, either by using the boot menu command 'boot_snap_delete' or by using the CLI command 'vol online -r'.
- Syslog Message
VBN %llu has RAID inconsistency errors on volume %s. This block is in use by one or more snapshots. These snapshots should be deleted in the next boot. The affected snapshot IDs are: %s.
- Parameters
volname (STRING): Name of the volume.
snapstring (STRING): The string containing the list of snapid(s) of the snapshots that have the inconsistent blocks.
wafl.raid.incons.ssd.cached.buf
- Severity
NOTICE
- Description
This message occurs when the WAFL® kernel detects an inconsistent cached block on a ssd disk in a hybrid aggregate. Any access to this block will result in the io getting redirected to the source location on hdd disk.
- Corrective Action
An error on a cached ssd block will not result in bad data being served to the reader: the io will be redirected to hdd and the correct data will be served. So, no corrective action is necessary for this case. But, if there are many errors on data cached on ssd disks, then the ssd disks may be verified for disk consistency.
- Syslog Message
WAFL inconsistent: bad cached ssd block %llu (vvbn:%llu fbn:%llu level:%u) in %s inode (fileid:%s snapid:%u file_type:%d disk_flags:0x%x error:%u) in volume %s%s%s%s. IO will be redirected to the source hdd block %llu.
- Parameters
vbn (LONGINT): Volume SSD block number.
file_space (STRING): File space: private or public.
fileid (STRING): Identifying number for the inode.
hdd_vbn (LONGINT): Volume HDD block number.
wafl.raid.incons.userdata
- Severity
ERROR
- Description
This message occurs when the WAFL® kernel detects an inconsistent user data block on a disk. Access to this block is disabled until you recover it from a backup.
- Corrective Action
The volume has an inconsistent user data block. Use the "volume file show-inode" command with the file ID and volume name information to find the file path. Recover the file from a backup. For a SnapMirror® target, rebuild from the source or resynchronize. If the block is in a Snapshot(tm) copy, delete the Snapshot copy. Contact NetApp technical support for more options.
- Syslog Message
WAFL inconsistent: inconsistent user data block at VBN %llu (vvbn:%llu fbn:%llu level:%u) in %s inode (fileid:%s snapid:%u file_type:%d disk_flags:0x%x error:%u raid_set:%d) in volume %s%s%s%s.
- Parameters
wafl.raid.incons.xidata
- Severity
EMERGENCY
- Description
This message occurs when the WAFL® kernel detects an inconsistent extended inode data block on disk.
- Corrective Action
- Syslog Message
WAFL inconsistent: bad extended inode data block at VBN %llu (vvbn:%llu fbn:%llu) in inode (fileid:%u snapid:%u disk_flags:0x%x error:%u raid_set:%d) in volume %s%s%s%s.
- Parameters
fileid (INT): Identifying number for the suspect inode.
