ONTAP EMS reference
air.disable events
air.disable EMS events occur when ONTAP encounters issues associated with inconsistencies in the async delete trashbin directory or the preserve unlink trash directory.
air.disable.async.delete.cli
Severity
ALERT
This message occurs when any inconsistency is found with the async delete trashbin directory of a volume.
Corrective Action
The "asynchronous directory delete from the client" feature has been disabled on this volume. To re-enable the feature, use the (privilege: advanced) "volume file async-delete client enable" command
Syslog Message
The "async directory delete from the client" feature was disabled in volume %s, after an inconsistency was detected with the trashbin directory.
volume (STRING): Name of the volume.
source (STRING): Location of the failing metadata validation.
