ONTAP EMS reference
appdm.l2 events
appdm.l2 EMS events occur when the system fails to notify the host of an event.
appdm.l2.notifyfailed
Severity
ERROR
This message occurs when the system fails to notify the host of an event.
Corrective Action
Verify the network connection between the host and the storage system to determine whether network communication is working correctly. If the condition persists, contact NetApp technical support.
Syslog Message
On Vserver %s, application component %s, failed to notify the host of event: %s with error %s.
vsUuid (STRING): UUID of the Vserver that failed to notify the host.
appCompUuid (STRING): UUID of the application component.
notificationMsg (STRING): Description of the event.
errorString (STRING): Description of the failure.
