ONTAP EMS reference
appdm.l2snap events
appdm.l2snap EMS events occur when ONTAP encounters issues associated with Snapshot copy operations between the storage system and the host.
appdm.l2snap.createfailed
Severity
ERROR
This message occurs when the Snapshot(tm) copy create request between the storage system and the host experiences a failure.
Corrective Action
Verify the network connection between the host and the storage system to determine whether network communication is working correctly. If the condition persists, contact NetApp technical support.
Syslog Message
On Vserver %s, application %s, component %s, creating Snapshot copy %s failed: %s.
vsUuid (STRING): UUID of the Vserver for which to perform the Snapshot copy create operation.
appUuid (STRING): UUID of the application.
appCompUuid (STRING): UUID of the application component.
snapshotName (STRING): Name of the Snapshot copy to be created.
errorString (STRING): Description of the failure.
appdm.l2snap.deletefailed
Severity
ERROR
This message occurs when the Snapshot(tm) copy delete request between the storage system and the host experiences a failure.
Corrective Action
Syslog Message
On Vserver %s, application component %s, deleting Snapshot copy %s failed: %s.
vsUuid (STRING): UUID of the Vserver for which to perform the Snapshot copy delete operation.
snapshotUuid (STRING): UUID of the Snapshot copy to be deleted.
appdm.l2snap.listfailed
Severity
ERROR
This message occurs when the Snapshot(tm) copy list request between the storage system and the host experiences a failure.
Corrective Action
Syslog Message
On Vserver %s, application component %s, listing Snapshot copy failed: %s.
vsUuid (STRING): UUID of the Vserver for which to perform the Snapshot copy list operation.
