The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
asup.smtp events
Creating your file...
Your file is ready
asup.smtp.drop
- Severity
ERROR
- Description
This message occurs when the AutoSupport® mechanism drops email messages after having retried for the specified times.
- Corrective Action
Use the "system node autosupport check show-details" command to check for connectivity errors with the configured mailhost. If the connectivity check shows no errors and if the problem persists, contact NetApp technical support for further assistance.
- Syslog Message
AutoSupport mail (%s) was not sent. The system will drop the message.
- Parameters
subject (STRING): AutoSupport message title.
