aws.dev events
aws.dev EMS events occur when ONTAP encounters issues associated with data disk failures, duplicate UUIDs, or device attachment limits in Amazon Web Services (AWS) instances.
aws.dev.diskFailure
- Severity
ERROR
- Description
This message occurs when ONTAP® is running as an instance in Amazon Web Services (AWS), and a data disk failure occurs because of an I/O hang. ONTAP marks the disk as broken and marks the data aggregrate as partial or degraded.
- Corrective Action
Detach the failed device from the AWS instance.
- Syslog Message
Disk failure detected after I/O to device %s hung for %d seconds.
- Parameters
dev (STRING): Name of the device.
timeout (INT): Number of seconds the disk is hung.
aws.dev.diskNotUnique
- Severity
ERROR
- Description
This message occurs when Data ONTAP® is running as an instance in Amazon Web Services (AWS), and the volume being added has a UUID that is already used by the attached volumes. This usually happens when the user creates a Snapshot® copy from a volume, creates the volume from this copy and then tries to attach the volume to the instance.
- Corrective Action
Detach the being added duplicate UUID device from the AWS instance.
- Syslog Message
The volume #%d(%s) being added has a duplicate UUID which is already used by the attached volume #%d(%s).
- Parameters
curr_unit (INT): Unit number of the device which is being attached.
curr_devname (STRING): Name of the device which is being attached.
orig_unit (INT): Unit number of the original device which is being duplicated.
orig_devname (STRING): Name of the original device which is being duplicated.
aws.dev.limitExceeded
- Severity
ERROR
- Description
This message occurs when Data ONTAP® is running as an instance in Amazon Web Services (AWS), and the volume being added is attached to an unsupported device name. Data ONTAP supports attaching a maximum of 51 Elastic Block Storage (EBS) volumes to a single instance. Supported device names are xvdf-xvdz, xvdaa-xvdaz, and xvdba-xvdbd.
- Corrective Action
Detach the unsupported device from the AWS instance.
- Syslog Message
The volume being added is attached to an unsupported device name #%d(%s). Data ONTAP supports attaching a maximum of 51 device volumes to a single instance. Supported device names are xvdf-xvdz, xvdaa-xvdaz, and xvdba-xvdbd.
- Parameters
unit (INT): Device unit number.
devname (STRING): Device name.
