The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
callhome.root events
Creating your file...
Your file is ready
callhome.root.vol.recovery.reqd
- Severity
EMERGENCY
- Description
This message occurs when the root volume is not working properly and its recovery is required. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
- Corrective Action
Contact NetApp technical support to obtain the root volume recovery procedures and further assistance.
- Syslog Message
Call home for ROOT VOLUME NOT WORKING PROPERLY: RECOVERY REQUIRED.
- Parameters
subject (STRING): AutoSupport subject or title for this event.
