ONTAP EMS reference
callhome.unsupported events
callhome.unsupported EMS events occur when the system generates an AutoSupport event to notify you that a SnapLock® disk is attached to a system running a release of ONTAP® that does not support SnapLock.
callhome.unsupported.snaplock
Severity
ALERT
This message occurs when the system generates an AutoSupport event to notify you that a SnapLock® disk is attached to a system running a release of ONTAP® that does not support SnapLock.
Corrective Action
Remove the SnapLock disks from this system and attach them to a system that supports SnapLock. You can also revert or upgrade this system to a release that supports SnapLock.
Syslog Message
Call home for SNAPLOCK DISKS IN UNSUPPORTED RELEASE
subject (STRING): AutoSupport subject or title for this event.
