cf.diskinventory events
Creating your file...
Your file is ready
cf.diskinventory.cksum.fail
- Severity
ALERT
- Description
This message occurs when the computed checksum of the disk inventory message is different from the checksum sent as part of the disk inventory message.
- Corrective Action
(None).
- Syslog Message
Disk inventory checksum mismatch: old %d new %d.
- Parameters
oldCkSum (INT): Old checksum, sent as part of the message.
newCkSum (INT): Checksum of the disk inventory message computed locally.
cf.diskinventory.many.disks
- Severity
INFORMATIONAL
- Description
This message occurs when a node receives more than maximum supported disks in the disk inventory message.
- Corrective Action
(None).
- Syslog Message
disk inventory: ndisks %d max_disks %d
- Parameters
ndisks (INT): Number of disk descriptions sent in the inventory message.
maxdisks (INT): Maximum number of disks supported.
