cft.trans events
cft.trans EMS events occur when ONTAP encounters issues associated with Copy-Free Transition of 7-Mode aggregates and volumes to clustered Data ONTAP.
cft.trans.aggr.end
- Severity
INFORMATIONAL
- Description
This message occurs when Copy-Free Transition of a 7-Mode aggregate to clustered Data ONTAP® is successful.
- Corrective Action
(None).
- Syslog Message
Copy-Free Transition session:%s on node "%s" for aggregate UUID:%s using Snapshot:%s completed successfully.
- Parameters
sessionId (STRING): Unique session identification number.
node (STRING): Name of the target controller.
aggrUuid (STRING): UUID of the aggregate.
snapshot (STRING): Aggregate Snapshot® copy name.
cft.trans.aggr.failed
- Severity
ALERT
- Description
This message occurs when Copy-Free Transition of a 7-Mode aggregate to clustered Data ONTAP® fails.
- Corrective Action
Contact technical support for assistance.
- Syslog Message
Copy-Free Transition session:%s on node "%s" for aggregate UUID:%s using Snapshot:%s failed.
- Parameters
cft.trans.aggr.start
- Severity
INFORMATIONAL
- Description
This message occurs when Copy-Free Transition of a 7-Mode aggregate to clustered Data ONTAP® starts.
- Corrective Action
(None).
- Syslog Message
Copy-Free Transition session:%s on node "%s" for aggregate UUID:%s using Snapshot:%s started.
- Parameters
cft.trans.commit.end
- Severity
INFORMATIONAL
- Description
This message occurs when Copy-Free Transition commit on a transitioned aggregate in clustered Data ONTAP® is successful.
- Corrective Action
(None).
- Syslog Message
Copy-Free Transition session:%s commit phase for aggregate UUID:%s" completed successfully.
- Parameters
cft.trans.commit.failed
- Severity
EMERGENCY
- Description
This message occurs when Copy-Free Transition commit of a transitioned aggregate in clustered Data ONTAP® fails.
- Corrective Action
- Syslog Message
Copy-Free Transition session:%s commit phase for aggregate UUID:%s " failed.
- Parameters
cft.trans.commit.start
- Severity
INFORMATIONAL
- Description
This message occurs when Copy-Free Transition commit of a transitioned aggregate in clustered Data ONTAP® starts.
- Corrective Action
(None).
- Syslog Message
Copy-Free Transition session:%s commit phase for aggregate UUID:%s" started.
- Parameters
cft.trans.revert.end
- Severity
INFORMATIONAL
- Description
This message occurs when a Copy-Free Transition revert operation for an aggregate is successfully completed.
- Corrective Action
(None).
- Syslog Message
Copy-Free Transition session:%s revert to Data ONTAP 7-Mode version:%s for aggregate UUID:%s on node "%s" completed successfully.
- Parameters
kernelVersion (STRING): Kernel Version of 7-Mode needed for the revert operation.
cft.trans.revert.failed
- Severity
ALERT
- Description
This message occurs when a Copy-Free Transition revert operation of a transitioned aggregate in clustered Data ONTAP® fails.
- Corrective Action
- Syslog Message
Copy-Free Transition session:%s revert to Data ONTAP 7-Mode version:%s for aggregate UUID:%s on node "%s" failed.
- Parameters
kernelVersion (STRING): Kernel version of 7-Mode needed for the revert operation.
cft.trans.revert.start
- Severity
INFORMATIONAL
- Description
This message occurs when a Copy-Free Transition revert for an aggregate starts.
- Corrective Action
(None).
- Syslog Message
Copy-Free Transition session:%s revert to Data ONTAP 7-Mode version:%s for aggregate UUID:%s on node "%s" started.
- Parameters
cft.trans.vol.end
- Severity
INFORMATIONAL
- Description
This message occur when Copy-Free Transition's volume transition job, responsible for transitioning 7-Mode volumes to clustered Data ONTAP®, is complete. It provides the details of the number of successful transitions and the number of failures, with references for rectification and corrective measures.
- Corrective Action
(None).
- Syslog Message
Copy-Free Transition session:%s volume transition job for %d volumes is complete. %d volumes transitioned successfully and %d volumes failed.
- Parameters
numVolumes (INT): Number of volumes transitioning.
successTransVols (INT): Number of volumes successfully transitioned.
failedTransVols (INT): Number of volumes that failed to transition.
cft.trans.vol.failed
- Severity
ERROR
- Description
This message occurs when Copy-Free Transition of a 7-Mode volume to clustered Data ONTAP® fails.
- Corrective Action
- Syslog Message
Copy-Free Transition session:%s for volume UUID:%s contained in aggregate UUID:%s and associated with Vserver "%s" failed.
- Parameters
volUuid (STRING): Volume unique identifier.
aggrUuid (STRING): UUID of the containing aggregate.
vserver (STRING): Vserver associated with the volume.
cft.trans.vol.start
- Severity
INFORMATIONAL
- Description
This message occurs when Copy-Free Transition's volume transition job, responsible for transitioning 7-Mode volumes to clustered Data ONTAP®, starts.
- Corrective Action
(None).
- Syslog Message
Copy-Free Transition session:%s volume transition job for %d volumes started.
- Parameters
