config.differentswitchport events
config.DifferentSwitchPort
Severity
ALERT
This message occurs when the two ports of the disk are connected to different switch ports.
Corrective Action
(None).
Syslog Message
Disks on port %s:%d are also connected to port %s:%d. They need to be connected via the same port on different switches. This is an illegal configuration.
switch1 (STRING): (None).
port1 (INT): (None).
switch2 (STRING): (None).
port2 (INT): (None).
