config.repl events
config.repl.bypass.disabled
- Severity
NOTICE
- Description
This message occurs when the configuration replication bypass has been disabled. Configuration replication to any partner clusters will now resume.
- Corrective Action
(None).
- Syslog Message
The configuration replication bypass has been disabled.
- Parameters
(None).
config.repl.bypass.enabled
- Severity
NOTICE
- Description
This message occurs when the configuration replication bypass has been enabled. Configuration replication to any partner clusters will cease until the bypass is disabled using the 'debug crs replication-bypass disable' command.
- Corrective Action
(None).
- Syslog Message
The configuration replication bypass has been enabled.
- Parameters
(None).
