ONTAP EMS reference
config.sameswitch events
config.SameSwitch
Severity
ALERT
This message occurs when both ports of a disk is found to be attached to the same switch.
Corrective Action
(None).
Syslog Message
Disks on port %s:%d are also connected to the same switch at port %s:%d. This is an illegal configuration.
switch1 (STRING): name of the switch
port1 (INT): port number of 1st connection.
switch2 (STRING): (None).
port2 (INT): port number of 2nd connection.
