ONTAP EMS reference
configbr.deletefailed events
configbr.deletefailed EMS events occur when an old configuration backup cannot be deleted.
configbr.deleteFailed
Severity
ERROR
This message occurs when an old configuration backup cannot be deleted.
Corrective Action
Ensure that the node is accessible and healthy. If necessary, delete the backup manually with the (privilege: advanced) "system configuration backup delete" command.
Syslog Message
The %s configuration backup %s on node %s cannot be deleted. Error: '%s'.
type (STRING): Type of backup, either cluster or local.
backup (STRING): Backup file.
node (STRING): Node on which the backup file exists.
reason (STRING): Reason for the error.
