The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cpeer.localid events
Creating your file...
Your file is ready
cpeer.localid.bad
- Severity
ERROR
- Description
This message occurs when there is an issue reading the local cluster ID. This indicates a serious problem with the cluster which may affect processes outside of cluster peering.
- Corrective Action
(Call support).
- Syslog Message
Unexpected local cluster ID: %s.
- Parameters
id (STRING): The string representation of the bad cluster ID.
