dbs.clone events
dbs.clone EMS events occur when a distributed block store event related to volume cloning occurs.
dbs.clone
- Severity
NOTICE
- Description
This message occurs when a distributed block store event related to volume cloning occurs. If the original distributed block store event specifies multiple drives, then an EMS event is generated for each drive.
- Corrective Action
None.
- Syslog Message
A distributed block store event \"%s\" of type \"%s\" for Service ID %u on node %u Drive ID = %u. Event ID = %u.
- Parameters
evtMessage (STRING): Description of the distributed block store event, including context details.
evtType (STRING): Type of the original distributed block store event.
serviceID (INT): Service ID that identifies the associated distributed block store service. It is "0" if there is no asociated service.
nodeID (INT): Node ID number of the associated node. It is "0" if there is no associated node.
driveID (INT): Drive ID number of the associated drive. It is "0" if there is no associated drive.
evtID (INT): Distributed block store event ID number.
evtDetails (STRING): Specific details of the distributed block store event. It might a string, in JSON format, or empty.
