dbs.remote events
dbs.remote EMS events occur when a Distributed Block Store event such as a change in cluster pair connectivity status occurs.
dbs.remote.cluster
- Severity
NOTICE
- Description
This message occurs when a Distributed Block Store (DBS) event such as a change in cluster pair connectivity status occurs. If the original DBS event specifies multiple drives, then an EMS event is generated for each drive.
- Corrective Action
None.
- Syslog Message
This is a Distributed Block Store remote cluster event. The event is \"%s\" of type \"%s\" for Service ID \"%u\" on node \"%u\". Drive ID = %u. Event ID = %u.
- Parameters
evtMessage (STRING): Description of the DBS event, including context details.
evtType (STRING): Type of the original DBS event.
serviceID (INT): Service ID that identifies the associated DBS service. It will be "0" if there is no associated service.
nodeID (INT): Node ID number of the associated node. It will be "0" if there is no associated node.
driveID (INT): Drive ID number of the associated drive. It will be "0" if there is no associated drive.
evtID (INT): DBS event ID number.
evtDetails (STRING): Specific details of the DBS event. It may be a string, in JSON format, or empty.
