ONTAP EMS reference
disk.ddr events
disk.ddr EMS events occur when ONTAP encounters issues associated with Dynamic Drive Recognition (DDR) operations.
disk.ddr.dqp.out.of.date
Severity
NOTICE
This message occurs when the Dynamic Drive Recognition (DDR) Scanner detects a disk that is not part of its qualification table.
Corrective Action
Check your support provider's web site or knowledgebase for more information about downloading and installing an updated Disk Qualification Package (DQP) file.
Syslog Message
The DDR Scanner has detected that the latest DQP is not present on this system.
(None).
disk.ddr.invalid.azcs.capacity
Severity
ERROR
This event is generated when the DDR Scanner detects a capacity value that does not match with the alias string associated with it.
Corrective Action
(None).
Syslog Message
The DDR Scanner has detected an invalid AZCS alias capacity on disk %s
diskname (STRING): Name of the disk.
capacity_value (LONGINT): The value of the invalid capacity
disk.ddr.invalid.bcs.capacity
Severity
ERROR
Corrective Action
(None).
Syslog Message
The DDR Scanner has detected an invalid BCS alias capacity on disk %s
disk.ddr.scanner.ddr.failure
Severity
NOTICE
This event is issued when a the ddr scanner has failed to read the new DDR label it just placed on the disk.
Corrective Action
(None).
Syslog Message
Disk %s Shelf %s Bay %s [%s %s %s] S/N [%s] [%s]: DDR label verify Failure - DDR Error
disk_name (STRING): The name of the disk
shelf (STRING): Shelf identifier where the disk is located
bay (STRING): Disk bay within the shelf where disk is located
vendor (STRING): Name of the vendor of the disk
model (STRING): Model string of the disk drive
firmware_revision (STRING): Firmware revision of the disk
serialno (STRING): Serial number of the disk
ddr_error (STRING): DDR Error string which has been parsed
disk.ddr.scanner.label.done
Severity
NOTICE
This event is issued when a the ddr scanner has completed has completed scanning a disk successfully
Corrective Action
(None).
Syslog Message
Disk %s Shelf %s Bay %s [%s %s %s] S/N [%s] : DDR label write complete
disk.ddr.scanner.verify.failure
Severity
NOTICE
Corrective Action
(None).
Syslog Message
Disk %s Shelf %s Bay %s [%s %s %s] S/N [%s] : DDR label verify Failure
disk.ddr.scanner.write.failure
Severity
NOTICE
This event is issued when a the ddr scanner has failed to write a new DDR label to the disk
Corrective Action
(None).
Syslog Message
Disk %s Shelf %s Bay %s [%s %s %s] S/N [%s] : DDR label write Failure
disk.ddr.unable.add.disk
Severity
ALERT
This event is generated when the DDR Scanner is unable to re-add a disk to the filer after trying for 2 minutes. This means there are no more spare disk_Cbs in the filer.
Corrective Action
(None).
Syslog Message
The filer has not freed a disk_Cb for over 2 mintues for %s.
diskuid (STRING): The unique identifier of the disk
