disk.fw events
disk.fw.autodownrev
Severity
INFORMATIONAL
This message occurs when the system detects disks with firmware that is not up-to-date. The background firmware update program will update the firmware automatically if the correct firmware files are in place.
Corrective Action
Download the correct firmware file onto the system. Check your support provider's web site or knowledgebase for more information about obtaining the latest disk firmware.
Syslog Message
%d disks have downrev firmware. They will be updated automatically using background disk firmware update if the correct firmware files are in place.
driveCount (INT): Number of disks that need to have updated firmware.
disk.fw.downrevWarning
Severity
ERROR
Corrective Action
Download and install the latest disk firmware file. Check your support provider's web site or knowledgebase for more information about obtaining the latest disk firmware.
Syslog Message
%d disks have downrev firmware that you need to update.
