dump.inconsistent events
dump.inconsistent EMS events occur when ONTAP encounters issues associated with disk errors during dump operations.
dump.inconsistent.acl_data
- Severity
ERROR
- Description
This message occurs when the dump engine encounters a disk error in an ACL file in a Snapshot(tm) copy. Backup will abort.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
Dump of source path (%s), Snapshot copy ID (%d): WAFL ACL data inconsistent due to disk errors. Aborting the backup.
- Parameters
src_path (STRING): Source path being backed up.
snap_id (INT): ID of the Snapshot copy where the disk error was encountered.
dump.inconsistent.file_data
- Severity
ERROR
- Description
This message occurs when the dump engine encounters a disk error in a file in a Snapshot(tm) copy. Backup will abort because the user selected the option to abort on disk error.
- Corrective Action
- Syslog Message
Dump of source path (%s), Snapshot copy ID (%d), inum (%u): WAFL data inconsistent due to disk errors. Aborting the backup as directed by ndmpd.abort_on_disk_error option.
- Parameters
inum (INT): Inode number of the file that encountered the disk error.
dump.inconsistent.ind_buf
- Severity
ERROR
- Description
This message occurs when the dump engine encounters a disk error in indirect buffers of a file in a Snapshot(tm) copy. Backup will abort because the user selected the option to abort on disk error.
- Corrective Action
- Syslog Message
Dump of source path (%s), Snapshot copy ID (%d), inum (%u): WAFL metadata and data inconsistent due to disk errors. Aborting the backup as directed by ndmpd.abort_on_disk_error option.
- Parameters
dump.inconsistent.stream_data
- Severity
ERROR
- Description
This message occurs when the dump engine encounters a disk error in a stream associated with a file in a Snapshot(tm) copy. Backup will abort because the user selected the option to abort on disk error.
- Corrective Action
- Syslog Message
Dump of source path (%s), Snapshot copy ID (%d), stream inum (%u), base inum(%u): WAFL data inconsistent due to disk errors. Aborting the backup as directed by ndmpd.abort_on_disk_error option.
- Parameters
sinum (INT): Inode number of the stream that encountered the disk error.
inum (INT): Inode number of the basefile whose associated stream encountered the disk error.
dump.inconsistent.wafl_metadata
- Severity
ERROR
- Description
This message occurs when the dump engine encounters a disk error in either the inode file, a directory or a stream directory in a Snapshot(tm) copy. As a result of this error, the backup is aborted.
- Corrective Action
- Syslog Message
Dump of source path (%s), Snapshot copy ID (%d): WAFL metadata inconsistent due to disk errors. Aborting the backup.
- Parameters
