ONTAP EMS reference
flexcache.config events
flexcache.config EMS events occur when the FlexCache volume expand operation fails to synchronize the FlexCache configuration information between the newly created constituent volume and the origin cluster.
flexcache.config.sync.failed
Severity
ERROR
This message occurs when the FlexCache volume expand operation fails to synchronize the FlexCache configuration information between the newly created constituent volume and the origin cluster.
Corrective Action
Use the "volume flexcache config-refresh" command on the origin cluster to update the FlexCache configuration.
Syslog Message
Volume expand failed to create the cache configuration for FlexCache volume "%s" in Vserver "%s" on the origin of the FlexCache cluster. Error: %s.
cacheVolName (STRING): Name of the FlexCache volume.
cacheVserver (STRING): Name of the Vserver hosting the FlexCache volume.
errorString (STRING): Error string.
