flexcache.mcc events
Creating your file...
flexcache.mcc.refresh.failed
- Severity
ERROR
- Description
This message occurs when a FlexCache® configuration refresh operation fails during MetroCluster(tm) switchover and switchback. Data access through FlexCache volumes might be impacted as a result.
- Corrective Action
First, verify that the two Vservers in question are peered by using the "vserver peer show" command. Next, enter the "flexcache config-refresh -peer-server <peer-vserver> -peer-volume <peer-volume> -peer-endpoint-type <peer-endpoint-type>" command on a node within the cluster that directly manages the peer endpoint.
- Syslog Message
FlexCache configuration refresh failed on peer Vserver %s for peer volume %s and peer endpoint %s on cluster %s.
- Parameters
peeredVserverUuid (STRING): UUID of the peered Vserver.
peerVolumeName (STRING): Name of the peer volume.
peerEndPointType (STRING): Peer endpoint type.
clusterUuid (STRING): UUID of the cluster with the peer endpoint.
localVserverUuid (STRING): UUID of the local Vserver.
