      fmmb.major events
fmmb.major.reset.invalid
- Severity
ALERT
 - Description
This event is issued when the HA Mailbox major reset data should exist and it doesn't. The major reset data in the mailbox is created and used when there is a major change of information kept in the HA mailbox records.
 - Corrective Action
(None).
 - Syslog Message
HA %s Mailbox major reset header information is invalid.
 - Parameters
host (STRING): The node which owns the HA mailbox disk. The node can be either local or partner.
