The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
fmmb.mmr events
Creating your file...
Your file is ready
fmmb.MMR.payload.bad
- Severity
ALERT
- Description
This event is issued when the outbound FM payload area is found to be corrupted and the master mailbox record is missing.
- Corrective Action
(None).
- Syslog Message
%s outbound FM payload area is invalid and the master mailbox record is missing.
- Parameters
host (STRING): The node which owns the HA mailbox disk. The node can be either local or partner.
