ha.netpartition events
ha.netpartition EMS events occur when ONTAP encounters issues associated with high-availability (HA) network partition detection.
ha.netPartition
- Severity
NOTICE
- Description
This message occurs when a Data ONTAP® subsystem detects an error potentially due to network partitioning, but cannot take over the partner node or allow the partner to take over because both takeover-of-partner and takeover-by-partner are both disabled. Network partitioning is indicated by concurrent errors on more than one of a node's interfaces, if a halt, reboot, takeover or similar action affecting connectivity is not already in progress.
- Corrective Action
(None).
- Syslog Message
Network partition error. Internal error code %d; status: 0x%x; internal request ID: %d.
- Parameters
error_code (INT): Internal error code.
error_status (INTHEX): Additional internal status bits related to error_code.
req_id (INT): Internal request ID.
duration (LONGINT): Elapsed time in msecs spent resolving the reported error.
ha.netPartition.reboot
- Severity
NOTICE
- Description
This message occurs when a Data ONTAP® subsystem detects an error potentially due to network partitioning, and reboots the local node due to the network partition. The reboot occurs only if ` takeover-by-partner is enabled on the local node. Network partitioning is indicated by concurrent errors on more than one of a node's interfaces, if a halt, reboot, takeover or similar action affecting connectivity is not already in progress.
- Corrective Action
(None).
- Syslog Message
Rebooting the local node due to a network partition error. Internal error code %d; status: 0x%x; internal request ID: %d.
- Parameters
ha.netPartition.takeover
- Severity
NOTICE
- Description
This message occurs when a Data ONTAP® subsystem detects an error potentially due to network partitioning, and initiates a takeover of the partner node due to the partition. Network partitioning is indicated by concurrent errors on more than one of a node's interfaces, if a halt, reboot, takeover or similar action affecting connectivity is not already in progress.
- Corrective Action
(None).
- Syslog Message
Taking over the partner node due to a network partition error. Internal error code %d; status: 0x%x; internal request ID: %d.
- Parameters
