ONTAP EMS reference
hypervisor.cpu events
hypervisor.cpu EMS events occur when ONTAP encounters issues associated with hypervisor CPU requirements for ONTAP Select.
hypervisor.cpu.count
Severity
ALERT
This message occurs when the number of physical CPUs on the hypervisor are not sufficient for ONTAP® Select support.
Corrective Action
Add more CPUs to the ONTAP® Select hypervisor configuration.
Syslog Message
Insufficient number of CPUs on the hypervisor is: %d. ONTAP® Select requires: %d
count (INT): Number of CPUs on the hypervisor.
minimum (INT): Minimum number of CPUs required on the hypervisor.
hypervisor.cpu.version
Severity
ALERT
This message occurs when the hypervisor CPU type running ONTAP® Select is not supported. Supported types are the XEON E5 v3 or later.
Corrective Action
Move ONTAP® Select to a hypervisor with a supported CPU.
Syslog Message
Unsupported hypervisor CPU: %s
version (STRING): Current version of the CPU.
