hypervisor.guest events
hypervisor.guest EMS events occur when ONTAP encounters issues associated with hypervisor guest configuration requirements for ONTAP Select.
hypervisor.guest.cpu
- Severity
ALERT
- Description
This message occurs when the hypervisor does not have a sufficient number of CPUs configured to support an ONTAP® Select guest.
- Corrective Action
Configure the required number of CPUs in the hypervisor configuration to support an ONTAP® Select guest.
- Syslog Message
Insufficient CPUs configured for the ONTAP® Select guest on the hypervisor: %d. %d CPUs are required.
- Parameters
count (INT): Number of CPUs currently configured.
required (INT): Required number of CPUs to be configured.
hypervisor.guest.guests
- Severity
ALERT
- Description
This message occurs when the number of ONTAP® Select guests exceeds the recommended limit.
- Corrective Action
Reduce the number of guests on the hypervisor to meet the requirements for ONTAP® Select.
- Syslog Message
Unsupported number of ONTAP® Select guests on the hypervisor: %d. Maximum supported number of guests: %d.
- Parameters
count (INT): Number of ONTAP® Select guests.
required (INT): Maximum number of ONTAP® Select guests.
hypervisor.guest.if.count
- Severity
ALERT
- Description
This message occurs when the hypervisor does not have a sufficient number of virtual network interfaces configured for the guest for ONTAP® Select support.
- Corrective Action
Verify that enough virtual network interfaces are configured to meet the requirements for ONTAP® Select.
- Syslog Message
Insufficient number of virtual network interfaces configured for the ONTAP® Select guest on the hypervisor: %d. %d interfaces are required.
- Parameters
count (INT): Number of virtual network interfaces configured.
required (INT): Required number of virtual network interfaces to be configured.
hypervisor.guest.if.speed
- Severity
ALERT
- Description
This message occurs when the speed of the virtual network interface configured for the guest is not sufficient for ONTAP® Select support.
- Corrective Action
Configured the speed of the virtual network interface to meet the required speed for ONTAP® Select support.
- Syslog Message
The speed of interface %s configured for the ONTAP® Select guest on the hypervisor is insufficient: %s. Required speed: %s.
- Parameters
name (STRING): Name of the virtual network interface.
speed (STRING): Speed of the configured virtual network interface.
required (STRING): Required speed of virtual network interface to be configured.
hypervisor.guest.if.status
- Severity
ALERT
- Description
This message occurs when a guest's virtual network interface is not operational.
- Corrective Action
The interface, port, or cabling needs to be investigated for faults. The interface must be "up" to meet the requirements for ONTAP® Select.
- Syslog Message
Virtual network interface %s assigned to the ONTAP® Select guest is not operational. Current status: %s.
- Parameters
status (STRING): Operational status of the virtual network interface.
hypervisor.guest.memory
- Severity
ALERT
- Description
This message occurs when the hypervisor does not have a sufficient amount of memory configured for the guest for ONTAP® Select support.
- Corrective Action
Configure the required amount of memory in the hypervisor configuration to support an ONTAP® Select guest.
- Syslog Message
Insufficient amount of memory configured for the ONTAP® Select guest on the hypervisor: %s. Required memory: %s.
- Parameters
amount (STRING): Amount of memory configured.
required (STRING): Required amount of memory to be as configured.
