ONTAP EMS reference
hypervisor.memory events
hypervisor.memory EMS events occur when the amount of memory installed on the hypervisor is not sufficient for ONTAP Select support.
hypervisor.memory.size
Severity
ALERT
This message occurs when the amount of memory installed on the hypervisor is not sufficient for ONTAP® Select support.
Corrective Action
Add more memory to the ONTAP® Select hypervisor configuration.
Syslog Message
Insufficient amount of memory on the hypervisor: %s. ONTAP® Select requires: %s of memory.
size (STRING): Size of memory active on the hypervisor.
required (STRING): Size of memory required on the hypervisor.
