ONTAP EMS reference
ic.linkspeeddegraded events
ic.linkspeeddegraded EMS events occur when the high-availability (HA) interconnect detects a degraded link speed.
ic.linkSpeedDegraded
Severity
ERROR
This message occurs when the high-availability (HA) interconnect detects a degraded link speed.
Corrective Action
For externally connected links, make sure that the interconnect cables are connected properly and that small form-factor pluggable (SFP) modules, if applicable, are seated properly on both controllers. For internally connected links, disable and reenable the links one at a time by using the (privilege: advanced) "system ha interconnect link off" and "system ha interconnect link on" commands. If the problem persists, contact NetApp technical support.
Syslog Message
HA interconnect: Link speed of link #%d degraded. Current: %s, expected: %s.
link_num (INT): Number that identifies the link.
link_speed (STRING): Current link speed.
expected_speed (STRING): Link speed expected for the HA interconnect device.
