ipsec.ib events
ipsec.ib.bad.encrypt
- Severity
ALERT
 - Description
This message occurs when an inbound IPsec packet cannot be successfully decrypted. Corrupt data is received.
 - Corrective Action
The IPsec SA database could be out of sync to cause this decryption failure. Use the "security ipsec policy modify -is-enabled" command to disable and then reenable the affected policy matching the source and destination IP address.
 - Syslog Message
IPsec: %s packet cannot be successfully decrypted.
 - Parameters
sa2str (STRING): IPsec Security Association (SA) in string format SA (Security Parameter Index, source IP address, destination IP address).
ipsec.ib.no.lookup
- Severity
ALERT
 - Description
This message occurs when an inbound IPsec packet cannot able to locate the IPsec Security Association (SA) from the SA database. The remote side is using an SA which does not exist in the local SA database.
 - Corrective Action
The IPsec SA database is out of sync. Use the "security ipsec policy modify -is-enabled" command to disable and then reenable the affected policy matching the source and destination IP address.
 - Syslog Message
IPsec: SA not found. SPI: %s Src IP: %s Dst IP: %s.
 - Parameters
spi (STRING): IPsec SA Security Parameter Index (SPI).
srcAddr (STRING): Source IP address.
dstAddr (STRING): Destination IP address.
ipsec.ib.no.replay
- Severity
NOTICE
 - Description
This message occurs when an inbound IPsec Security Association (SA) encounters a replay check failure. Number of out-of-order and retransmitted IPsec packet received. Possible causes include a denial-of-service (DoS) attack or traffic congestion.
 - Corrective Action
Possible traffic congestion or DoS attack.
 - Syslog Message
IPsec: %s replay packets detected. Possible DoS attack or traffic congestion.
 - Parameters
sa2str (STRING): IPsec SA in string format SA (Security Parameter Index, source IP address, destination IP address).
ipsec.ib.policy.violation
- Severity
ALERT
 - Description
This message occurs when an inbound IPsec packet is found to violate the security policy. It is either not IPsec protected or it is protected in a different way than the policy specifies.
 - Corrective Action
check the IPsec policy configuration on both ends to make sure that they match each other.
 - Syslog Message
IPsec: Inbound %s packet %s =⇒ %s security policy violation.
 - Parameters
protocol (STRING): Packet protocol.
