The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
iscsi.session events
Creating your file...
Your file is ready
iscsi.session.stateChanged
- Severity
NOTICE
- Description
This message occurs when iSCSI session status is changed.
- Corrective Action
If the identified iSCSI session is experiencing unexpected events (disconnecting, reconnecting, or connected), examine the link for excessive errors or latency.
- Syslog Message
iSCSI session state is changed to %s for the target %s (type: %s, address: %s). %s
- Parameters
iscsi_session_state (STRING): New iSCSI session state.
iscsi_target (STRING): iSCSI target name.
iscsi_target_type (STRING): iSCSI target type.
iscsi_target_address (STRING): iSCSI target address.
iscsi_session_state_change_reason (STRING): Reason for the iSCSI session state change.
iscsi_timeout_value (INT): iSCSI timeout value.
