ONTAP EMS reference
master.promoting events
master.promoting EMS events occur when a node is promoted to the cluster master.
master.promoting.cm
Severity
NOTICE
This message occurs when the node is promoted to the cluster master and takes constrol as the master.
Corrective Action
(None).
Syslog Message
Service ID "%u" on node ID "%u" is taking over as the cluster master.
serviceID (INT): Service ID that identifies the associated master service.
nodeID (INT): Node ID number of the associated node.
