mgmtgwd.sign events
mgmtgwd.sign.cert.expired
Severity
ERROR
This message occurs when a digital certificate for a Vserver expires. Client-server communication is not secure.
Corrective Action
Sign a new digital certificate on the system using the 'security certificate sign' command.
Syslog Message
A digital certificate with Fully Qualified Domain Name (FQDN) %s, Serial Number %s, Certificate Authority '%s' and Certificate Authority Serial Number %s for Vserver %s has expired.
common_name (STRING): Name of the Fully Qualified Domain Name(FQDN) whose digital certificate expired.
serial_number (STRING): Serial Number of the digital certificate.
certificate_authority (STRING): Name of the Certificate Authority.
ca_serial_number (STRING): Serial Number of the Certificate Authority(CA) that signed the digital certificate.
vserver (STRING): Name of the Vserver.
mgmtgwd.sign.cert.expiring
Severity
ERROR
This message occurs when a digital certificate for a Vserver is about to expire. Client-server communication will not be secure if the certificate expires.
Corrective Action
Syslog Message
A digital certificate with Fully Qualified Domain Name (FQDN) %s, Serial Number %s, Certificate Authority '%s' and Certificate Authority Serial Number %s for Vserver %s will expire in %d day(s).
common_name (STRING): Name of the Fully Qualified Domain Name(FQDN) whose digital certificate is about to expire.
certificate_authority (STRING): Name of the Certificate Authority whose digital certificate that is about to expire.
ca_serial_number (STRING): Serial Number of Certificate Authority(CA) that signed the digital certificate.
days (INT): Number of days remaining until the certificate expires.
