ONTAP EMS reference
mgr.stack events
mgr.stack EMS events occur when ONTAP encounters issues associated with panic information.
mgr.stack.at
Severity
NOTICE
This message contains the panic string.
Corrective Action
(None).
Syslog Message
Panic occurred at: %s
time (STRING): The time string
mgr.stack.checkpoint
Severity
NOTICE
Logs the last checkpoint dumpcore crossed before failing.
Corrective Action
(None).
Syslog Message
Dumpcore failure: At checkpoint %d
checkpoint (INT): (None).
mgr.stack.frame
Severity
NOTICE
The stack frame: frame number, functionname, base, offset.
Corrective Action
(None).
Syslog Message
Stack frame %2d: %s(0x%llx) + 0x%x
frame (INT): The frame number
sym (STRING): The symbolic name
base (PTR): The base address
offset (INTHEX): The offset
mgr.stack.frameaddr
Severity
NOTICE
The stack frame: frame number, (no function name), base, offset.
Corrective Action
(None).
Syslog Message
Stack frame %2d: 0x%llx + 0x%x
mgr.stack.framebase
Severity
NOTICE
The stack frame: frame number, base address.
Corrective Action
(None).
Syslog Message
mgr.stack.longrun.proc
Severity
NOTICE
The name of the process that hogged the cpu too long.
Corrective Action
(None).
Syslog Message
Long running process: %s
name (STRING): The name of the process
mgr.stack.noFrames
Severity
NOTICE
This message is emitted when no stack frames are available. This is normal on platforms which do not support stack tracing, or when the prior release did not support stack trace.
Corrective Action
(None).
Syslog Message
No stack frames available
(None).
mgr.stack.proc
Severity
NOTICE
The name of the process that we took the panic in.
Corrective Action
(None).
Syslog Message
Panic in process: %s
mgr.stack.saved
Severity
NOTICE
This message indicates that we've saved panic information in the NV RAM.
Corrective Action
(None).
Syslog Message
Reboot with saved panic information in log file
(None).
mgr.stack.string
Severity
NOTICE
Corrective Action
(None).
Syslog Message
Panic string: %s
string (STRING): The panic string
