The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mpt.busreg events
Creating your file...
Your file is ready
mpt.busreg.phydisk.failed
- Severity
ERROR
- Description
This message occurs when physical disk bus registration fails in the message processing technology (MPT) adapter driver.
- Corrective Action
Check whether the device is connected correctly.
- Syslog Message
%s : Physical disk bus registration failed.
- Parameters
mpt (STRING): MPT device name on the path that failed.
