nameserv.config events
nameserv.config.write.failed
Severity
ERROR
This message occurs when a file write for name service configuration fails.
Corrective Action
Autocorrection is triggered for failing Vserver, configuration and node. Ensure that the root volume File System(FS) is available and has enough space and check the status using "vserver services name-service file-version show". Contact technical support if the problem persists.
Syslog Message
%s configuration failed for Vserver %s on node %s.
vserver_name (STRING): Name of the Vserver.
ns_config_name (STRING): Name of the name service configuration.
node_name (STRING): Name of the node.
