nblade.cifsmaxwatchespertree events
Nblade.cifsMaxWatchesPerTree
- Severity
ERROR
- Description
This message occurs when the total number of directory watch (Change Notify) requests exceed the per-tree limit. This request and any further directory watch requests are denied. This typically indicates abnormal client behavior.
- Corrective Action
Inspect the application using the connection and also monitor the other applications on the client. The client might be operating incorrectly due to a faulty application running on it. Rebooting the client might also be helpful. In some cases, clients are operating as expected but require a higher threshold, which can be set using the (privilege: advanced) "cifs option modify -max-watches-set-per-tree" command.
- Syslog Message
Received too many Change Notify requests on one tree: clientIP:port %s:%d, directory "%s" on share "%s", vserver: "%s".
- Parameters
IpAddress (STRING): IP address of the client requesting Change Notify functionality.
 port (INT): Port number of the client from which the TCP connection has been established.
 dirPath (STRING): Path of the directory on which Change Notify is requested.
 shareName (STRING): Name of the share that holds the directory.
 vserverName (STRING): Vserver associated with this operation.
 PDFs
PDFs
