ONTAP EMS reference
nblade.nfsv4poolexhaust events
Nblade.nfsV4PoolExhaust
Severity
EMERGENCY
This message occurs when one of the NFSv4 store pools is exhausted.
Corrective Action
If the NFS server is unresponsive for more than 10 minutes after this error occurs, contact NetApp technical support.
Syslog Message
NFS Store Pool for %s exhausted. Associated object type is %s with UUID: %s.
poolname (STRING): NFSv4 store pool type where the exhaustion happened.
object_type (STRING): Type of the resource object under notification.
object_uuid (STRING): UUID of the resource object.
