ONTAP EMS reference
nodewatchdog.node events
nodewatchdog.node EMS events occur when ONTAP encounters issues associated with node internal service failures.
nodewatchdog.node.failure
Severity
EMERGENCY
This message occurs when Data ONTAP® experiences a prolonged outage of internal services critical to continued data service. The node experiencing this failure might operate in a degraded mode until the condition is addressed. Data ONTAP will attempt to recover by restarting the affected process.
Corrective Action
The affected process may produce a core file which can be analyzed. Contact NetApp technical support if the condition persists and possible analysis of the core file.
Syslog Message
Data ONTAP has experienced a serious internal error: %s. This might cause the node experiencing the problem to become unresponsive to data access.
condition (STRING): Condition that caused the failure.
diagnosis (STRING): List of system diagnoses that could cause node watchdog issues.
nodewatchdog.node.longreboot
Severity
ALERT
This message occurs when a node fails to reboot within the configured time allowed for rebooting.
Corrective Action
Contact NetApp technical support.
Syslog Message
Data ONTAP has experienced a serious internal error. The node experiencing this problem is unable to reboot within it's allotted time of %d seconds causing it to be unavailable. The node has been panicked to enable it to recover.
timeout (INT): The time in seconds within which reboot did not complete.
nodewatchdog.node.panic
Severity
ALERT
This message occurs when Data ONTAP® experiences a prolonged outage of internal services critical to continued data service. The node has been restarted to recover from the condition.
Corrective Action
Contact NetApp technical support for additional assistance.
Syslog Message
Data ONTAP has experienced a serious internal error: %s. This might cause the node experiencing the problem to become unresponsive to data access. %s
action (STRING): Automatic corrective action taken (or why avoided) as a result of detecting this condition.
nodewatchdog.node.ucore.hung
Severity
ALERT
This message occurs when a node fails to generate an application core within the time allotted for application coredump due to a serious internal error. The node is panicked to recover from the internal error.
Corrective Action
Syslog Message
Unable to generate an application core for %s (pid %d) within the allotted time of %d seconds causing the application to become unavailable. The node has been panicked to recover.
process_name (STRING): Name of the application that failed to generate core.
process_id (INT): PID of the application that failed to generate core.
timeout (INT): Time in seconds within which the application coredump did not complete.
