nse.op events
nse.op.failed
Severity
ERROR
This message occurs when ONTAP® does not succeed in performing an operation on a NetApp® Storage Encryption (NSE) self-encrypting drive (SED). The message applies to drives that implement either the Trusted Computing Group (TCG) "Enterprise" or "Opal" specification. Some aspect of the operation of NSE drives is compromised.
Corrective Action
If the error persists, replace the drive.
Syslog Message
Control failure on self-encrypting drive %s; security provider: %s, authority: %s, during operation "%s".
deviceName (STRING): Name of the device.
securityProvider (STRING): Name of the TCG security provider process.
authority (STRING): Name of the affected TCG authority.
operation (STRING): Description of the operation that failed.
