nvram.battery events
nvram.battery EMS events occur when ONTAP encounters issues associated with NVRAM battery capacity and charging status.
nvram.battery.capacity.low.critical
- Severity
EMERGENCY
- Description
This message occurs when the NVRAM battery capacity is critically low. To prevent data loss, the system will shut down.
- Corrective Action
Correct any environmental problems, such as chassis over- temperature. The battery charges automatically. If the capacity is not restored automatically within 30 minutes after system power is on, replace the NVRAM battery. If the problem persists, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery capacity is critically low (%s). To prevent data loss, the system will shut down in %d minutes.
- Parameters
reading (STRING): Reading that triggered this message.
num_minutes (INT): Number of minutes until the system shuts down.
nvram.battery.capacity.low.warn
- Severity
NOTICE
- Description
This message occurs when the NVRAM battery capacity is below normal.
- Corrective Action
Correct any environmental problems, such as chassis over- temperature. The battery charges automatically. If the capacity is not restored automatically within 30 minutes after system power is on, replace the NVRAM battery within three months. If the problem persists, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery capacity is below normal (%s).
- Parameters
nvram.battery.capacity.normal
- Severity
INFORMATIONAL
- Description
This message occurs when the NVRAM battery capacity is normal.
- Corrective Action
(None).
- Syslog Message
The NVRAM battery capacity is normal.
- Parameters
(None).
nvram.battery.capacityLow
- Severity
ERROR
- Description
This message occurs when the NVRAM battery capacity is low. To prevent data loss, the system will schedule a clean chassis shutdown if the problem is not corrected.
- Corrective Action
- Syslog Message
The NVRAM battery capacity is low (%s).
- Parameters
nvram.battery.chargeFET.normal
- Severity
INFORMATIONAL
- Description
This message occurs when the NVRAM battery charge FET is on.
- Corrective Action
(None).
- Syslog Message
The NVRAM battery charge FET is on.
- Parameters
(None).
nvram.battery.chargeFET.off
- Severity
ERROR
- Description
This message occurs when the NVRAM battery charge FET is off. To prevent data loss, the system will initiate a clean chassis shutdown if the problem is not corrected within 24 hours of first detection.
- Corrective Action
Shut down the system and power-cycle the controller. If the charge FET remains off, replace the NVRAM battery. If the problem persists, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery charge FET is off. To prevent data loss, the system will shut down %s.
- Parameters
countdown (STRING): Remaining time before chassis shutdown.
nvram.battery.charging.nocharge
- Severity
EMERGENCY
- Description
This message occurs when the NVRAM battery is requesting to be charged but the charger is not charging the battery. To prevent data loss, the system will shut down.
- Corrective Action
Reseat the NVRAM battery connector. If the problem occurs again, replace the NVRAM battery. If the problem persists, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery is requesting to be charged but the charger is not charging the battery. To prevent data loss, the system will shut down in %d minutes.
- Parameters
nvram.battery.charging.normal
- Severity
INFORMATIONAL
- Description
This message occurs when the NVRAM battery charging status is normal.
- Corrective Action
(None).
- Syslog Message
The NVRAM battery charging status is normal.
- Parameters
(None).
nvram.battery.charging.wrongcharge
- Severity
ERROR
- Description
This message occurs when the NVRAM battery charger is charging the battery even though the battery is not requesting to be charged. To prevent data loss, the system will initiate a clean chassis shutdown if the problem is not corrected within 24 hours of first detection.
- Corrective Action
Replace the NVRAM battery. If the problem persists, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery charger is charging the battery even though the battery is not requesting to be charged. To prevent data loss, the system will shut down %s.
- Parameters
nvram.battery.current.high
- Severity
EMERGENCY
- Description
This message occurs when the NVRAM battery charging current is critically high. To prevent data loss, the system will shut down.
- Corrective Action
- Syslog Message
The NVRAM battery current is critically high (%s). To prevent data loss, the system will shut down in %d minutes.
- Parameters
nvram.battery.current.high.warn
- Severity
ERROR
- Description
This message occurs when the NVRAM battery charging current is above normal. To prevent data loss, the system will initiate a clean chassis shutdown if the problem is not corrected within 24 hours of first detection.
- Corrective Action
- Syslog Message
The NVRAM battery current is above normal (%s). To prevent data loss, the system will shut down %s.
- Parameters
nvram.battery.current.low
- Severity
EMERGENCY
- Description
This message occurs when the NVRAM battery detects a short circuit. To prevent data loss, the system will shut down.
- Corrective Action
Contact NetApp technical support for assistance with identification and replacement of the appropriate component.
- Syslog Message
The NVRAM battery has a short circuit (%s). To prevent data loss, the system will shut down in %d minutes.
- Parameters
nvram.battery.current.low.warn
- Severity
ERROR
- Description
This message occurs when the NVRAM battery is discharging when it should not. To prevent data loss, the system will initiate a clean chassis shutdown if the problem is not corrected within 24 hours of first detection.
- Corrective Action
- Syslog Message
The NVRAM battery current is below normal (%s). To prevent data loss, the system will shut down %s.
- Parameters
nvram.battery.current.normal
- Severity
INFORMATIONAL
- Description
This message occurs when the NVRAM battery current is normal.
- Corrective Action
(None).
- Syslog Message
The NVRAM battery current is normal.
- Parameters
(None).
nvram.battery.dischargeFET.normal
- Severity
INFORMATIONAL
- Description
This message occurs when the NVRAM battery discharge FET is on.
- Corrective Action
(None).
- Syslog Message
The NVRAM battery discharge FET is on.
- Parameters
(None).
nvram.battery.dischargeFET.off
- Severity
EMERGENCY
- Description
This message occurs when the NVRAM battery discharge FET is off. To prevent data loss, the system will shut down.
- Corrective Action
Shut down the system and power-cycle the controller. If the discharge FET remains off, replace the NVRAM battery. If the problem persists, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery discharge FET is off. To prevent data loss, the system will shut down in %d minutes.
- Parameters
nvram.battery.endOfLife.high
- Severity
INFORMATIONAL
- Description
This message occurs when the NVRAM battery-cycle count indicates that the battery has reached its anticipated life expectancy.
- Corrective Action
Replace the NVRAM battery in the next three months.
- Syslog Message
The NVRAM battery has reached its anticipated life expectancy.
- Parameters
(None).
nvram.battery.endOfLife.normal
- Severity
INFORMATIONAL
- Description
This message occurs when the NVRAM battery-cycle count indicates that the battery is well below its anticipated life expectancy.
- Corrective Action
(None).
- Syslog Message
The NVRAM battery is well below its anticipated life expectancy.
- Parameters
(None).
nvram.battery.fault
- Severity
EMERGENCY
- Description
This message occurs when the NVRAM battery is reporting a fatal fault condition. To prevent data loss, the system will shut down.
- Corrective Action
Correct any environmental problems, such as chassis over-temperature. If the battery still reports a fatal fault, replace the NVRAM battery. If the problem persists, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery is reporting a fatal fault condition. To prevent data loss, the system will shut down in %d minutes.
- Parameters
nvram.battery.fault.cleared
- Severity
INFORMATIONAL
- Description
This message occurs when the NVRAM battery internal fault condition has been cleared.
- Corrective Action
(None).
- Syslog Message
The NVRAM battery internal fault condition has been cleared.
- Parameters
(None).
nvram.battery.fault.warn
- Severity
NOTICE
- Description
This message occurs when the NVRAM battery is reporting a non-fatal fault condition.
- Corrective Action
Correct any environmental problems, such as chassis over- temperature. If the condition persists, replace the NVRAM battery in the next three months.
- Syslog Message
The NVRAM battery is reporting a non-fatal fault condition.
- Parameters
(None).
nvram.battery.fcc.low
- Severity
ERROR
- Description
This message occurs when the NVRAM battery full-charge capacity is low. To prevent data loss, the system will initiate a clean chassis shutdown if the problem is not corrected within 24 hours of first detection.
- Corrective Action
Use the "sysconfig -M" command in 7-Mode or the "run local sysconfig -M" command in clustered Data ONTAP® to get the battery manufacturer date. If the battery is newer than three years old, correct any chronic environmental problems, such as chassis over-temperature. Replace the NVRAM battery. If the problem persists, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery full-charge capacity is low (%s). To prevent data loss, the system will shut down %s.
- Parameters
nvram.battery.fcc.low.critical
- Deprecated
Deprecated as of version 9.2.0 to address the EMS ID length violation.
- Severity
EMERGENCY
- Description
This message occurs when the NVRAM battery full-charge capacity is critically low. To prevent data loss, the system will shut down.
- Corrective Action
- Syslog Message
The NVRAM battery full-charge capacity is critically low (%s). To prevent data loss, the system will shut down in %d minutes.
- Parameters
nvram.battery.fcc.low.warn
- Severity
NOTICE
- Description
This message occurs when the NVRAM battery full-charge capacity is below normal.
- Corrective Action
Replace the NVRAM battery in the next three months. Use the "sysconfig -M" command in 7-Mode or the "run local sysconfig -M" command in clustered Data ONTAP® to get the battery manufacturer date. If the battery is newer than three years old, correct any chronic environmental problems, such as chassis over-temperature.
- Syslog Message
The NVRAM battery full-charge capacity is below normal (%s).
- Parameters
nvram.battery.fcc.normal
- Severity
INFORMATIONAL
- Description
This message occurs when the NVRAM battery full-charge capacity is normal.
- Corrective Action
(None).
- Syslog Message
The NVRAM battery full-charge capacity is normal.
- Parameters
(None).
nvram.battery.fccLowCrit
- Severity
EMERGENCY
- Description
- Corrective Action
Use the "system node run -node local sysconfig -M" command to obtain the battery manufacturing date. If the battery is over three years old, replacement might be necessary. Contact NetApp technical support for troubleshooting assistance.
- Syslog Message
- Parameters
nvram.battery.fcmto.warn
- Severity
NOTICE
- Description
This message occurs when the NVRAM battery fast-charge timeout expires. The battery will not be charged until this condition is corrected.
- Corrective Action
Shut down the controller and power cycle it from the Service Processor (SP) command line interface (CLI) with the "system power cycle" command. The fast-charge timeout will be reset after the power cycle.
- Syslog Message
The NVRAM battery has reached a charging timeout fault. The battery charger will not turn on again until the contoller has been power cycled. Low capacity warning messages begin in %s weeks.
- Parameters
num_weeks (STRING): Number of weeks before low capacity warning messages begin.
nvram.battery.not.present
- Severity
EMERGENCY
- Description
This message occurs when the NVRAM battery is not present. To prevent data loss, the system will shut down.
- Corrective Action
While the system is shut down, pull the controller from the slot and ensure that the NVRAM battery is present. If the NVRAM battery is already present, ensure that the connector is seated properly. Push the controller back in and power on the system. If this does not correct the problem, replace the NVRAM battery. If the system still does not detect the battery, replace either the field-replaceable unit (FRU) NVRAM card or the Plus-CPU Module (PCM), where the battery is located.
- Syslog Message
The NVRAM battery is not present. To prevent data loss, the system will shut down in %d minutes.
- Parameters
nvram.battery.pack.invalid
- Severity
ERROR
- Description
This message occurs when an unsupported NVRAM battery pack is installed in the system. To prevent data loss, the system initiates a clean chassis shutdown if the problem is not corrected within 24 hours of first detection.
- Corrective Action
Shut down the system and replace the NVRAM battery with a correct battery pack.
- Syslog Message
The incorrect NVRAM battery is installed. Expected part number is %s. To prevent data loss, the system will shut down in %d minutes.
- Parameters
partnum (STRING): Valid battery part number.
nvram.battery.pack.valid
- Severity
INFORMATIONAL
- Description
This message occurs when a valid NVRAM battery pack is now present and readable.
- Corrective Action
(None).
- Syslog Message
A valid NVRAM battery pack is present.
- Parameters
(None).
nvram.battery.power.fault
- Severity
EMERGENCY
- Description
This message occurs when the NVRAM battery is not receiving power. To prevent data loss, the system will shut down.
- Corrective Action
Pull the controller from the slot and ensure that the NVRAM battery connector is seated properly. Push the controller back in and boot up the system. If the NVRAM battery is still not receiving power, replace the NVRAM battery. If the problem persists, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery is not receiving power. To prevent data loss, the system will shut down in %d minutes.
- Parameters
nvram.battery.power.normal
- Severity
INFORMATIONAL
- Description
This message occurs when the NVRAM battery power is normal.
- Corrective Action
(None).
- Syslog Message
The NVRAM battery power is normal.
- Parameters
(None).
nvram.battery.sensor.unreadable
- Severity
EMERGENCY
- Description
This message occurs when the NVRAM battery state cannot be determined because the sensor is unreadable. To prevent data loss, the system will shut down.
- Corrective Action
Pull the controller from the slot and ensure that the NVRAM battery connector is seated properly. Push the controller back in and power on the system. If the problem is not corrected, replace the NVRAM battery. If the sensor is still not readable, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery state cannot be determined because the '%s' sensor is unreadable. To prevent data loss, the system will shut down in %d minutes.
- Parameters
sensor_name (STRING): Sensor name.
nvram.battery.temp.high
- Severity
EMERGENCY
- Description
This message occurs when the NVRAM battery temperature is critically high. To prevent data loss, the system will shut down.
- Corrective Action
Correct any environmental issues, such as a high ambient temperature. If the NVRAM battery temperature is still above normal, replace the NVRAM battery. If the problem persists, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery temperature is critically high (%s). To prevent data loss, the system will shut down in %d minutes.
- Parameters
nvram.battery.temp.high.warn
- Severity
NOTICE
- Description
This message occurs when the NVRAM battery temperature is above normal. Battery life will be severely compromised.
- Corrective Action
- Syslog Message
The NVRAM battery temperature is above normal (%s).
- Parameters
nvram.battery.temp.low
- Severity
ERROR
- Description
This message occurs when the NVRAM battery is too cold. To prevent data loss, the system will initiate a clean chassis shutdown if the problem is not corrected within 24 hours of first detection.
- Corrective Action
If the system is excessively cold, allow it to warm gradually. If the NVRAM battery temperature is still too low, replace the NVRAM battery. If the problem persists, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery is too cold (%s). To prevent data loss, the system will shut down %s.
- Parameters
nvram.battery.temp.low.warn
- Severity
NOTICE
- Description
This message occurs when the NVRAM battery temperature is below normal.
- Corrective Action
Allow the system to warm gradually. If the NVRAM battery temperature is still low, replace the NVRAM battery. If the problem persists, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery temperature is below normal (%s).
- Parameters
nvram.battery.temp.normal
- Severity
INFORMATIONAL
- Description
This message occurs when the NVRAM battery temperature is normal.
- Corrective Action
(None).
- Syslog Message
The NVRAM battery temperature is normal.
- Parameters
(None).
nvram.battery.voltage.high
- Severity
EMERGENCY
- Description
This message occurs when the NVRAM battery voltage is critically high. To prevent data loss, the system will shut down.
- Corrective Action
- Syslog Message
The NVRAM battery voltage is critically high (%s). To prevent data loss, the system will shut down in %d minutes.
- Parameters
nvram.battery.voltage.high.warn
- Severity
ERROR
- Description
This message occurs when the NVRAM battery voltage is above normal. To prevent data loss, the system will initiate a clean chassis shutdown if the problem is not corrected within 24 hours of first detection.
- Corrective Action
Correct any environmental problems, such as chassis over- temperature. If the NVRAM battery voltage is still above normal, replace the NVRAM battery. If the problem returns or persists, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery voltage is above normal (%s). To prevent data loss, the system will shut down %s.
- Parameters
nvram.battery.voltage.low
- Severity
EMERGENCY
- Description
This message occurs when the NVRAM battery voltage is critically low. To prevent data loss, the system will shut down.
- Corrective Action
Correct any environmental problems, such as chassis over- temperature. If the NVRAM battery voltage is still critically low, replace the NVRAM battery. If the problem persists, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery voltage is critically low (%s). To prevent data loss, the system will shut down in %d minutes.
- Parameters
nvram.battery.voltage.normal
- Severity
INFORMATIONAL
- Description
This message occurs when the NVRAM battery voltage is normal.
- Corrective Action
(None).
- Syslog Message
The NVRAM battery voltage is normal.
- Parameters
(None).
nvram.battery.voltageLowWarn
- Severity
ERROR
- Description
This message occurs when the NVRAM battery voltage is below normal. To prevent data loss, the system will schedule a clean chassis shutdown if the problem is not corrected.
- Corrective Action
Correct any environmental problems, such as chassis over- temperature. If the NVRAM battery voltage is still below normal 30 minutes after environmental problems have been corrected, replace the NVRAM battery. If the problem persists, replace the FRU (field-replaceable unit) NVRAM card or PCM, where the battery is located.
- Syslog Message
The NVRAM battery voltage is below normal (%s).
- Parameters
