pubsub.kernel events
pubsub.kernel.flow.control.enabled
Deprecated
This event is deprecated as of 9.10.0.
Severity
ERROR
This message will not be published as flow control is enabled on kernel pubsub.
Corrective Action
Check the network connectivity to the broker and ensure the broker is running properly.
Syslog Message
Kernel pubsub failed to send message with topic %s, object %s, object UUID %s and operation %s. Flow control is enabled.
topic (STRING): Topic of the message.
object (STRING): Object of the message.
object_uuid (STRING): Object UUID of the message.
operation (STRING): Operation of the message.
pubsub.kernel.send.msg.failed
Deprecated
Severity
ERROR
This message occurs when kernel pubsub fails to send a message to the broker.
Corrective Action
Syslog Message
Kernel pubsub failed to send message with topic %s, object %s, object UUID %s, operation %s, and error code %d.
error_code (INT): Error code associated with the failure.
