quota.scan events
Creating your file...
quota.scan.abort
- Severity
ERROR
- Description
This message occurs after the administrator uses the "volume quota on" command, when the quota scanner aborts without finishing due to an error condition. Any quotas configured on the volume will not be tracked or enforced.
- Corrective Action
If the volume quota status is not displayed as "off", turn quotas off by executing the "volume quota off" command, and then retry the "volume quota on" command. If this condition persists, contact NetApp technical support.
- Syslog Message
Quota scan aborted on %s %s%s%s%s.
- Parameters
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): Additional volume identifier, used to uniquely identify the volume if the volume name alone cannot.
quota.scan.cancel
- Severity
NOTICE
- Description
This message occurs after the administrator uses the "volume quota on" command, when the quota scanner is canceled by other activity in the system. An example of such activity would be the "volume quota off" command.
- Corrective Action
(None).
- Syslog Message
Quota scan canceled on %s %s%s%s%s.
- Parameters
quota.scan.complete
- Severity
NOTICE
- Description
This message occurs when the administrator uses the "volume quota on" command and the quota scanner has completed scanning.
- Corrective Action
(None).
- Syslog Message
Quota scan completed on %s %s%s%s%s.
- Parameters
quota.scan.start
- Severity
NOTICE
- Description
This message occurs when the administrator uses the "volume quota on" command and starts the quota scanner.
- Corrective Action
(None).
- Syslog Message
Quota scan started on %s %s%s%s%s.
- Parameters
