raid.disk events
raid.disk.capacity.info
Severity
NOTICE
This event is issued to inform what the sum of all disk sizes is as well as what system capacity limit is.
Corrective Action
(Call support).
Syslog Message
System capacity visible is %s of the %s maximum.
actual (STRING): Actual capacity of system
limit (STRING): Capacity limit of system
raid.disk.cksum.type.changed
Severity
INFORMATIONAL
This message occurs when a disk's checksum type changes from either block to zoned, or zoned to block. It might occur, for example, due to a disk firmware update or a user request.
Corrective Action
(None).
Syslog Message
Disk %s checksum type was changed from %s to %s.
disk_info (STRING): Formatted disk information
old_type (STRING): Old checksum type. "block" or "zoned".
new_type (STRING): New checksum type. "block" or "zoned".
shelf (STRING): Shelf identifier where the disk is located
bay (STRING): Disk bay within the shelf where disk is located
vendor (STRING): Name of the vendor of the disk
model (STRING): Model string of the disk drive
firmware_revision (STRING): Firmware revision number of the disk
serialno (STRING): Serial number of the disk
disk_type (INT): Type of disk drive
disk_rpm (STRING): Rotational speed of disk in RPM
carrier (STRING): Unique ID of the carrier in which the disk is installed.
site (STRING): For a MetroCluster(tm) configuration, indicates the site {Local|Remote} where the disk is located. For non-MetroCluster configurations, site is 'Local'.
raid.disk.failed.unknownPool
Severity
INFORMATIONAL
This event is issued when a disk is failed but is not in an aggregate or a known disk pool.
Corrective Action
(None).
Syslog Message
Failed %s without a tree but with a unknown pool as a parent.
disk_info (STRING): Formatted information of the disk
raid.disk.fast.zero.done
Severity
NOTICE
This message occurs when a fast zeroing operation is completed on a disk.
Corrective Action
(None).
Syslog Message
%s : disk zeroing complete (0x%llx).
disk_info (STRING): Formatted information about the disk which has completed its zeroing operation.
fz_signature (LONGINTHEX): Random generated unique fast zero signature.
fz_signature_old (LONGINTHEX): Random generated unique fast zero signature, previous one.
shelf (STRING): Identifier of the shelf where the disk is located.
bay (STRING): Disk bay within the shelf where the disk is located.
vendor (STRING): Name of the vendor of the disk.
model (STRING): Model string of the disk drive.
firmware_revision (STRING): Firmware revision number of the disk.
serialno (STRING): Serial number of the disk.
disk_type (INT): Type of disk drive.
disk_rpm (STRING): Rotational speed of disk in RPM.
raid.disk.home.id.changed
Severity
INFORMATIONAL
This event is issued when a change in a disk's home id is detected, independent of any disk change notification event.
Corrective Action
(None).
Syslog Message
(None).
old_home_id (STRING): Previous home host.
new_home_id (STRING): New home host.
old_home_sysid (LONGINT): Previous home sysid.
new_home_sysid (LONGINT): New home sysid.
raid.disk.illegalAttach
Severity
ALERT
This message occurs when ONTAP detects that a disk has been incorrectly attached to the system.
Corrective Action
Check disk shelf cabling and verify it meets SyncMirror requirements and wiring rules for this system.
Syslog Message
%s is illegally attached. %s
disk_info (STRING): Name of the disk.
err_string (STRING): Illegal Attach error.
instanceId (INT): Instance identifier.
shelf (STRING): Shelf identifier where the disk is located.
bay (STRING): Disk bay within the shelf where disk is located.
raid.disk.inserted
Severity
INFORMATIONAL
This event is issued when a disk is inserted into the system.
Corrective Action
(None).
Syslog Message
%s has been inserted into the system
disk_info (STRING): Formatted information of the disk object
raid.disk.io.bypass
Severity
INFORMATIONAL
This event is issued when a read error is detected but ignored because the aggregate is in media error bypass mode.
Corrective Action
(None).
Syslog Message
media error bypass enabled, ignoring read error on disk block %llu of %s
blockNum (LONGINT): The disk block number
disk_info (STRING): The formatted information of the disk
raid.disk.io.toFailedDisk
Severity
ERROR
This event is issued when an attempt is made to I/O a failed disk.
Corrective Action
In maintenance mode, remove ownership of this disk and assign the correct ownership
Syslog Message
DBG: %s is attempting I/O to failed %s
who (STRING): Module attempting I/O
raid.disk.maint.abort
Severity
NOTICE
This event occurs when the administrator aborts maintenance testing of a disk or when an error that is unrelated to the disk occurs. The disk is failed because testing could not be completed.
Corrective Action
(None).
Syslog Message
%s tests were aborted.
start_code (STRING): Start code for internal support use
end_code (STRING): End code for internal support use
disk_rpm (STRING): Rotational speed of disk, in RPM
raid.disk.maint.admin.abort
Severity
NOTICE
This event occurs when administrator-initiated maintenance testing of a disk is aborted by the administrator or when an error that is unrelated to the disk occurs. The disk is made available as a spare.
Corrective Action
(None).
Syslog Message
raid.disk.maint.admin.done
Severity
NOTICE
This event occurs when administrator- initiated maintenance testing of a disk is completed successfully. The disk is made available as a spare.
Corrective Action
(None).
Syslog Message
%s tests were completed successfully.
raid.disk.maint.admin.failed
Severity
NOTICE
This message occurs when a disk fails one or more maintenance tests. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
Corrective Action
(None).
Syslog Message
%s tests failed.
disk_info (STRING): Formatted information about the disk.
end_code (STRING): End code for internal support use.
model (STRING): Model string of the disk.
disk_type (INT): Type of disk.
disk_rpm (STRING): Rotational speed of the disk, in RPM.
raid.disk.maint.admin.start
Severity
NOTICE
This event occurs when the administrator starts maintenance testing on a disk.
Corrective Action
(None).
Syslog Message
%s will be tested.
start_reason (STRING): This states that the administrator started maintenance testing on a disk.
raid.disk.maint.bypassed
Severity
INFORMATIONAL
This message occurs when a disk that has an error bypasses maintenance testing, even though the error typically would cause the disk to enter the maintenance center. The reason might be that the maintenance center is disabled, that there are not enough spare disks available in the system, or that there are already the maximum number of disks in the maintenance center.
Corrective Action
(None).
Syslog Message
(None).
disk_info (STRING): Formatted information of the disk.
disk_type (INT): Type of the disk.
bypass_reason (STRING): Reason for bypassing maintenance testing on the disk.
raid.disk.maint.done
Severity
NOTICE
This event occurs when maintenance testing of a disk is completed successfully. The disk is made available as a spare.
Corrective Action
(None).
Syslog Message
raid.disk.maint.exceed
Severity
NOTICE
This message occurs when a disk exceeds the number of times it is allowed to be tested. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
Corrective Action
(None).
Syslog Message
%s exceeded the number of allowed entries to maintenance testing.
start_code (STRING): Start code for internal support use.
raid.disk.maint.failed
Severity
NOTICE
Corrective Action
(None).
Syslog Message
%s tests failed.
raid.disk.maint.start
Severity
NOTICE
This event occurs when a disk begins maintenance testing.
Corrective Action
(None).
Syslog Message
%s will be tested.
start_reason (STRING): The reason for starting maintenance testing on the disk.
raid.disk.mcc.mismatch
Severity
ERROR
This message occurs when a disk with a non-zero disaster recovery (DR) home ID is illegally attached to a system that is not configured for MetroCluster(tm) operation.
Corrective Action
To reuse this disk on a non MetroCluster enabled system, use the "storage disk removeowner" command, followed by the "storage disk assign" command.
Syslog Message
The disk %s was previously owned by a MetroCluster enabled system. This system is not configured for MetroCluster operations.
dr_home_owner_id (LONGINT): NVRAM system ID of the disk's DR home owner.
raid.disk.missing
Severity
INFORMATIONAL
This event is issued either when a disk is pulled from the system or when all paths to it have disappeared.
Corrective Action
(None).
Syslog Message
%s is missing from the system
raid.disk.offline
Severity
NOTICE
This event is issued when offlining a drive
Corrective Action
(None).
Syslog Message
Marking %s%s offline.
owner (STRING): The owner of the drive
raid.disk.online
Severity
NOTICE
This event is issued when onlining an offline drive.
Corrective Action
(None).
Syslog Message
Onlining %s%s.
raid.disk.online.fail
Severity
NOTICE
This event is issued if the drive failed while it was offline. The drive will be moved to broken pool as part of the online process.
Corrective Action
(None).
Syslog Message
Failing %s%s during online.
raid.disk.owner.change.fail
Severity
EMERGENCY
This message occurs when an ownership change request initiated by RAID, for either spare disks or the disks of an aggregate, fails due to an error from SANOWN.
Corrective Action
The system automatically retries changing ownership of the disks. If the condition persists, contact NetApp technical support.
Syslog Message
RAID initiated ownership change request failed (aggregate: %s error: %s). This request will be retried.
aggregate (STRING): Empty string for spare disks, or name of the aggregate for filesystem disks.
reason (STRING): Reason for failure.
retry_count (INT): Number of retry attempts.
disk_count (INT): Number of disks in the ownership change request.
raid.disk.owner.changed
Severity
INFORMATIONAL
This event is issued when change in a disk's owner is detected, independent of any disk change notification event.
Corrective Action
(None).
Syslog Message
(None).
old_owner (STRING): Previous disk owner.
new_owner (STRING): New disk owner.
old_owner_id (LONGINT): Old disk owner ID.
new_owner_id (LONGINT): New disk owner ID.
raid.disk.ownership.change
Severity
NOTICE
This message occurs when a non-filesystem disk is prepared for ownership change by administrator forcibly.
Corrective Action
(None).
Syslog Message
Ownership of %s, is being changed by administator forcibly.
shelf (STRING): Disk shelf identifier where the disk is located.
bay (STRING): Disk bay within the disk shelf where the disk is located.
raid.disk.pool.changed
Severity
INFORMATIONAL
This message occurs when a change in a disk's current pool is detected, independent of any disk change notification event.
Corrective Action
(None).
Syslog Message
(None).
disk_info (STRING): Formatted disk information.
old_pool (STRING): Previous pool for this disk.
new_pool (STRING): New pool for this disk.
raid.disk.predictiveFailure
Severity
ERROR
This message occurs when some condition of the disk indicates that it may fail soon. It is first marked as prefailed. If an appropriate spare is available, it will be selected for Rapid RAID Recovery. In that process, the prefailed disk will be copied to the spare. The filer will stop using the prefailed disk when copying is done. At that time, the disk may be removed and replaced.
Corrective Action
The raid.rg.diskcopy.done event is issued when the disk copy is complete. After that wait for the event message raid.disk.unload.done or raid.carrier.remove to be issued and then replace the carrier containing the failed disk. If the disk is contained in a single-disk carrier, raid.disk.unload.done will be issued immediately. Otherwise, wait for raid.carrier.remove which indicates the carrier has been fully prepared for removal.
Syslog Message
%s reported a predictive failure and it is prefailed; it will be copied to a spare and failed
raid.disk.read.abort.detect
Severity
NOTICE
This message occurs when a disk encounters an abort error during a read operation. The system retries the disk read request and gradually takes the disk out of service by copying the content to a replacement disk.
Corrective Action
(None).
Syslog Message
Read abort error encountered on %s, disk rebuild assist mode %s, block #%llu, length = %u; I/O will be retried.
disk_info (STRING): Formatted information of the disk. This includes the disk's containing volume name and other attributes, such as shelf, bay, vendor, model, firmware revision, serial number, and type.
disk_ra_mode (STRING): Disk rebuild assist mode indicating whether mode is enabled.
blockNum (LONGINT): Physical disk block number of the first block in this I/O chain.
length (INT): Number of disk blocks in this I/O chain.
error_code (INT): Error code returned by the disk driver.
vendor (STRING): Name of the disk vendor.
firmware_revision (STRING): Disk firmware revision number.
raid.disk.read.abort.recons
Severity
NOTICE
This message occurs when a disk encounters an abort error during a read operation, and a subsequent attempt to retry the read request fails. The system services the read request by reconstructing the data from parity data. The system gradually takes the disk out of service by copying the content to a replacement disk.
Corrective Action
(None).
Syslog Message
Read retry failed on %s, block #%llu.
blockNum (LONGINT): Physical disk block number on which the read operation failed.
raid.disk.replace.job.done
Severity
NOTICE
This message occurs when a disk replace job finishes successfully.
Corrective Action
(None).
Syslog Message
Disk %s replaced with disk %s.
srcName (STRING): Name of the source disk.
dstName (STRING): Name of the destination disk.
raid.disk.replace.job.failed
Severity
ERROR
This message occurs when a disk replace job fails.
Corrective Action
Take any corrective action indicated by the specific reason for the failure and then retry the disk replace operation. If the condition persists, contact NetApp technical support.
Syslog Message
Failed to replace disk %s with disk %s. Reason: %s.
raid.disk.replace.job.start
Severity
NOTICE
This message occurs when a job to replace a shared disk with a spare disk begins. The operation can be triggered either by an administrator or automatically by Data ONTAP®. A couple of such scenarios follows: a) There is a mix of drives from different SyncMirror® pools in the same plex of a mirrored aggregate. b) An aggregate is using a partitioned disk on an external shelf when there is a spare disk available on an internal shelf.
Corrective Action
(None).
Syslog Message
Starting disk replacement of disk %s with disk %s.
raid.disk.replace.job.stop
Severity
NOTICE
This message occurs when a disk replace job is stopped by an administrator.
Corrective Action
(None).
Syslog Message
Stopping disk replacement of disk %s with disk %s.
raid.disk.sanitization.aborted
Severity
INFORMATIONAL
This event is issued when disk sanitization is aborted using the "disk sanitize" abort" command.
Corrective Action
(None).
Syslog Message
Sanitization aborted for %s
raid.disk.sanitization.failed
Severity
INFORMATIONAL
This event is issued if disk sanitization fails due to a fatal error.
Corrective Action
(None).
Syslog Message
Sanitization failed for %s
site (STRING): For a MetroCluster(tm) configuration, indicates the site {Local|Remote} where the disk is located. For non-MetroCluster configurations, the site is 'Local'.
raid.disk.timeout.force.recovery
Severity
NOTICE
This event is issued when a disk continues to exhibit symptoms of long response times (timeouts) while it is in the process of being replaced via a copy. In this case, a forced recovery is initiated by removed the disk from the raid group. A complete rewrite of the disk is expected to help recover bad media patches.
Corrective Action
(None).
Syslog Message
Forcing recovery of %s%s as a result of exceeding timeout recovery threshold of %d.
owner (STRING): String indicating the owner of the affected volume.
disk_info (STRING): The name of the disk.
threshold (INT): Threshold for the maximum number of timeouts which can be tolerated while a disk is in the process of being replaced.
raid.disk.timeout.recommend.recovery
Severity
NOTICE
This event is issued when a disk repeatedly exhibits symptoms of long response times (timeouts) due to bad media patches. The disk is recommended for a full recovery as a result of crossing timeout recovery thresholds. The contents of the disk will be copied to a replacement. A complete rewrite of the disk is expected to help recover bad media patches.
Corrective Action
(None).
Syslog Message
%s%s recommended for recovery as a result of exceeding timeout recovery threshold of %d.
threshold (INT): Threshold for the maximum number of timeout recovery operations above which the disk is recommended for recovery.
raid.disk.timeout.recovery.invalid.range
Severity
NOTICE
This event is issued if an invalid blockNum range was reported during disk timeout recovery
Corrective Action
(None).
Syslog Message
Invalid block range reported for %s during disk timeout recovery : start %llu, end %llu
disk_info (STRING): Formatted information of the disk for which the invalid blockNum range was reported.
start (LONGINT): Starting disk block number for the recovery range
end (LONGINT): Ending disk block number for the recovery range
raid.disk.timeout.recovery.read.err
Severity
NOTICE
This event is issued when timeout recovery io detects a read error
Corrective Action
(None).
Syslog Message
Read error on %s%s, block #%llu during aggressive timeout recovery
owner (STRING): Owner of the affected aggregate.
disk_info (STRING): Formatted information of the disk object that contains the error.
blockNum (LONGINT): The physical block number containing the error.
raid.disk.tooBig.all.reminder
Severity
ERROR
This message occurs when the sum of disk sizes of all disks connected in the system exceed the maximum capacity supported for this platform.
Corrective Action
Contact NetApp technical support. For information about correcting the problem, search for the "raid.disk.tooBig.all.reminder" keyword on the Knowledgebase of the NetApp Support Site.
Syslog Message
System capacity %s exceeds the %s maximum supported disk capacity.
actual (STRING): Actual total capacity of disks currently connected to the system.
limit (STRING): Maximum supported disk capacity limit of the system.
raid.disk.unfail.done
Severity
INFORMATIONAL
This event is issued when a failed disk has been unfailed using the "disk unfail" command, and returned to service as a spare.
Corrective Action
(None).
Syslog Message
%s unfailed, and is now a spare
raid.disk.unfail.error
Severity
INFORMATIONAL
This event is issued when an error is encountered while attempting to unfail a disk.
Corrective Action
(None).
Syslog Message
%s could not be unfailed
error_str (STRING): A raid error string, describing the error encountered during disk unfail.
raid.disk.unfail.reassim
Severity
INFORMATIONAL
This event occurs when a failed disk was unfailed using the "disk unfail" command, and is in process of being reassimilated.
Corrective Action
(None).
Syslog Message
%s was unfailed, and is now being reassimilated
Severity
INFORMATIONAL
This event is issued when a failed or removed disk has been spun down by the driver.
Corrective Action
It is safe to pull the disk from the shelf.
Syslog Message
Unload of %s has completed successfully
raid.disk.verify.abort.detec
Severity
NOTICE
This message occurs when a disk encounters an abort error during a background media verify operation. The system gradually takes the disk out of service by copying the content to a replacement disk.
Corrective Action
(None).
Syslog Message
Media verify abort error encountered on %s, block #%llu, length = %llu.
length (LONGINT): Number of disk blocks in this I/O chain.
raid.disk.zero.aborted
Severity
NOTICE
This message occurs when disk zeroing has been aborted. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
Corrective Action
(None).
Syslog Message
%s : disk zeroing aborted (%s).
disk_info (STRING): Information about the disk object, including disk name, path, shelf, bay, serial number, vendor, model, RPM, carrier serial number, and site.
reason (STRING): Reason for abort.
model (STRING): Model name of the disk.
raid.disk.zero.done
Severity
NOTICE
This message occurs when a disk zeroing operation completes.
Corrective Action
(None).
Syslog Message
disk_info (STRING): Formatted information of disk object that has completed its zeroing operation
duration (INT): The amount of time the zeroing operation required, in seconds
raid.disk.zero.done.failed.die
Severity
NOTICE
Corrective Action
(None).
Syslog Message
%s : disk zeroing for failed die complete
raid.disk.zero.fake
Severity
NOTICE
This message occurs when disk zeroing has been faked on a disk.
Corrective Action
(Call support).
Syslog Message
%s: fake disk zeroing complete
disk_info (STRING): Formatted information of the disk on which zeroing has been faked
