ONTAP EMS reference
raid.labeledit events
raid.labeledit EMS events occur when you run the 'label buildtree' command to create an aggregate from a collection of disks.
raid.labeledit.buildtree
Severity
NOTICE
This event occurs when you run the 'label buildtree' command to create an aggregate from a collection of disks.
Corrective Action
(None).
Syslog Message
%s %s was created using the 'label buildtree' command.
voltype (STRING): Volume type.
volname (STRING): Name of the aggregate created by the command.
cmdline (STRING): Command line used to create the aggregate.
