raid.rg events
raid.rg.bigio.fatal
Severity
ALERT
This message occurs when a RAID group background long running I/O encounters an error that is fatal to the RAID group and the aggregate (cannot be fixed even by a mirror read from the other plex, if it exists).
Corrective Action
Contact technical support to bring this aggregate online.
Syslog Message
%s: long-running raid I/O operation experienced fatal multi-disk error.
rg (STRING): Name of the RAID group object that failed.
raid.rg.context.clear
Severity
NOTICE
This message occurs when the context flag is cleared from the RAID group, and therefore from the parent aggregate, as part of context parity scrub testing. This event is only logged during internal testing; it is not seen on customer systems.
Corrective Action
(None).
Syslog Message
Scrub testing: %s%s: group parity context is now reset.
owner (STRING): Owner of the RAID group.
rg (STRING): Name of the RAID group whose context flag is cleared.
raid.rg.degraded
Severity
NOTICE
This message occurs when a RAID group becomes degraded, double degraded, or triple degraded.
Corrective Action
Reconstruction will occur unless there is no matching spare disk or the number of failed disks is greater than the parity reconstruction level of the RAID group (1 for raid4, 2 for raid_dp and 3 for raid_tec). If reconstruction does not occur, then follow the following steps: 1. Identify the failed disk or disks from the system logs and determine the reason for the failure. 2. Replace the faulty disks.
Syslog Message
%s: Raid group %s is degraded
name (STRING): Relative path name of the RAID group.
aggr_UUID (STRING): Universal Unique Identifier (UUID) of the aggregate.
raid.rg.die_recons.aborted
Severity
NOTICE
This message occurs when die reconstruction has been aborted on a specific raid group.
Corrective Action
(None).
Syslog Message
%s%s: die reconstruction aborted at disk %s block %llu after %s
owner (STRING): Owner of the raid group.
rg (STRING): Name of the raid group object that is aborted die reconstruction.
disk (STRING): Name of the disk object for which die reconstruction aborted.
blockNum (LONGINT): The physical block number die reconstruction stopped
duration (STRING): The amount of time the die reconstruction required
aggregate_uuid (STRING): Universal Unique Identifier (UUID) of the aggregate.
raid.rg.die_recons.cant.start
Severity
NOTICE
This message occurs when the raid group has a disk with failed die but the die reconstruction cannot be started.
Corrective Action
(None).
Syslog Message
%s%s: unable to start die reconstruction for %s: %s.
disk (STRING): Name of the disk which has a failed die
reason (STRING): Reason the die reconstruction cannot start
raid.rg.die_recons.deferred
Severity
NOTICE
This message occurs when die reconstruction has been deferred on a specific raid group due to inadequate incore resources.
Corrective Action
(None).
Syslog Message
%s%s: die reconstruction deferred for %s (%s)
rg (STRING): Name of the raid group object that is unable to reconstruct die
reason (STRING): A text reason code
raid.rg.die_recons.done
Severity
NOTICE
This message occurs when die reconstruction has been completed on a specific raid group.
Corrective Action
(None).
Syslog Message
%s%s: die reconstruction completed for %s in %s.
disk_info (STRING): Information about the disk object, including disk name, path, shelf, bay, serial number, vendor, model, RPM, carrier serial number, and site.
disk (STRING): Name of the disk object for which die reconstruction completed.
duration (STRING): The amount of time the die reconstruction required.
shelf (STRING): Shelf identifier where the disk is located
bay (STRING): Disk bay within the shelf where disk is located
vendor (STRING): Name of the vendor of the disk
model (STRING): Model string of the disk drive
firmware_revision (STRING): Firmware revision number of the disk
serialno (STRING): Serial number of the disk
disk_type (INT): Type of disk drive
disk_rpm (STRING): Rotational speed of disk in RPM
carrier (STRING): Unique ID of the carrier in which the disk is installed.
site (STRING): For a MetroCluster(tm) configuration, indicates the site {Local|Remote} where the disk is located. For non-MetroCluster configurations, site is 'Local'.
raid.rg.die_recons.start
Severity
NOTICE
This message occurs when die reconstruction has been initiated on a specific raid group.
Corrective Action
(None).
Syslog Message
%s%s: starting die reconstruction on disk %s
disk (STRING): Name of the disk object where die reconstruction happens
raid.rg.disk.reconstruction.failed
Severity
NOTICE
This event is issued when a disk has failed reconstruction.
Corrective Action
(None).
Syslog Message
%s%s: reconstruction failed for a disk in the raidgroup
owner (STRING): The owner of the raid group
rg (STRING): The name of the raid group object containing the reconstructing disk
raid.rg.diskcopy.aborted
Severity
NOTICE
This message occurs when RAID disk copy is aborted. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
Corrective Action
(None).
Syslog Message
%s%s: disk copy from %s to %s aborted at disk block %llu after %s. Reason: %s.
rg (STRING): RAID group name.
source (STRING): Name of the source disk.
target (STRING): Name of the target disk.
blockNum (LONGINT): Physical block number where the disk copy stopped.
duration (STRING): Amount of time the disk copy lasted.
reason (STRING): Reason for aborting the disk copy operation
raid.rg.diskcopy.cant.start
Severity
NOTICE
This message occurs when RAID disk copy cannot be started. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
Corrective Action
(None).
Syslog Message
%s%s: unable to start disk copy for %s: %s.
rg (STRING): Name of the RAID group.
disk (STRING): Name of the disk to be copied.
reason (STRING): Reason the disk copy cannot start.
raid.rg.diskcopy.deferred
Severity
NOTICE
This message occurs when a RAID disk copy is deferred due to inadequate incore resources. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
Corrective Action
(None).
Syslog Message
%s%s: disk copy for %s deferred (%s).
reason (STRING): Reason code.
raid.rg.diskcopy.deferred.ok
Severity
INFORMATIONAL
This message occurs when a previously deferred RAID disk copy is now ready to proceed.
Corrective Action
(None).
Syslog Message
%s%s: disk copy for %s previously deferred, now proceeding.
raid.rg.diskcopy.done
Severity
INFORMATIONAL
This message occurs when RAID disk copy is completed.
Corrective Action
(None).
Syslog Message
%s%s: disk copy from %s (S/N [%s]) to %s (S/N [%s]) was completed in %s.
source_serialno (STRING): Serial number of the source disk.
target_serialno (STRING): Serial number of the target disk.
duration (STRING): Amount of time it took to complete the disk copy operation.
raid.rg.diskcopy.failed
Severity
NOTICE
This message occurs when RAID disk copy to the intended target disk cannot be initiated. This type of disk copy is used after new firmware download, to return the disk to its place in a RAID group. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
Corrective Action
(None).
Syslog Message
%s%s: unable to start disk copy from %s to %s: %s.
source (STRING): Name of the disk to be copied.
raid.rg.diskcopy.mismatch
Severity
ERROR
This message occurs when there is no disk for Rapid RAID Recovery that matches all parameters of an ideal replacement in the RAID group. Data ONTAP® selected a disk with a different interface speed or RPM, or from the opposite spare pool in a SyncMirror® configuration.
Corrective Action
Wait for copying to finish. Install an appropriate spare disk. Fail the mismatched disk by using the 'disk fail' command. It will be copied to the new spare disk. After copying is done, use the 'disk unfail' command to unfail the mismatched disk and convert it to a spare.
Syslog Message
%s%s: matching disk not available to copy disk %s; using disk %s %s.
detail (STRING): Description of disk mismatch; one or more of: from the opposite spare pool, with different RPM.
raid.rg.diskcopy.recom.fail
Severity
ERROR
This message occurs when an unhealthy disk drive being copied to a replacement disk cannot continue the copy, and must be recommended for failure before the copy is completed. The system will reconstruct the data from parity data.
Corrective Action
(None).
Syslog Message
%s recommend failed after exceeding disk copy error threshold.
disk_info (STRING): Formatted information of the disk. This includes the disk’s containing volume name and other attributes, such as shelf, bay, vendor, model, firmware revision, serial number, and type.
error_pct (INT): Number of bad blocks on the disk, described as percentage of the total size of the disk.
shelf (STRING): Shelf identifier where the disk is located.
bay (STRING): Disk bay within the shelf where the disk is located.
vendor (STRING): Name of the disk vendor.
model (STRING): Model string of the disk.
firmware_revision (STRING): Disk firmware revision number.
serialno (STRING): Serial number of the disk.
disk_type (INT): Type of disk.
disk_rpm (STRING): Rotational speed of the disk, in RPM.
raid.rg.diskcopy.resume
Severity
INFORMATIONAL
This message occurs when RAID disk copy is resumed.
Corrective Action
(None).
Syslog Message
%s%s: resuming disk copy from %s to %s (disk block %llu, %d%% complete)
blockNum (LONGINT): Physical block number from which disk copy is continuing.
percent (INT): Percentage of disk copy already complete.
raid.rg.diskcopy.start
Severity
NOTICE
This message occurs when RAID disk copy is initiated.
Corrective Action
(None).
Syslog Message
%s%s: starting disk copy from %s (S/N [%s]) to %s (S/N [%s]). Reason: %s.
reason (STRING): Reason for starting disk copy.
raid.rg.drecons
Severity
NOTICE
This message occurs when double reconstruction is initiated after the failure of two disks in RAID-DP or RAID-TEC raid group.
Corrective Action
(None).
Syslog Message
%s%s: starting double reconstruction, using disks %s and %s
rg (STRING): Name of the raid group object that is initiating double reconstruction.
disk (STRING): Name of the disk object that is the first reconstruction target.
disk1 (STRING): Name of the disk object that is the second reconstruction target.
raid.rg.intl.diskcopy.done
Severity
NOTICE
This message occurs when intelligent disk copy has been completed.
Corrective Action
(None).
Syslog Message
%s%s: intelligent disk copy completed for %s. Used DBN %llu copy done DBN %llu disk size %llu
rg (STRING): Name of the raid group object that is completed intelligent disk copy.
disk (STRING): Name of the disk object for which intelligent reconstruction completed.
used_dbn (LONGINT): Maximum used Disk block number.
copy_done_dbn (LONGINT): Disk block number when intelligent disk copy was done.
disk_size (LONGINT): Filesystem size of the disk.
raid.rg.intl.recons.done
Severity
NOTICE
This message occurs when intelligent reconstruction has been completed on a specific raid group.
Corrective Action
(None).
Syslog Message
%s%s: intelligent reconstruction completed for %s. Used DBN %llu reconstruction done DBN %llu disk size %llu
rg (STRING): Name of the raid group object that is completed intelligent reconstruction.
recons_done_dbn (LONGINT): Disk block number when intelligent reconstruction was done.
raid.rg.lw.prot.disabled
Severity
NOTICE
This message occurs when the lost-write protection for RAID I/O is disabled on the RAID group.
Corrective Action
(None).
Syslog Message
%s%s: group lost-write protection for RAID I/O is now disabled (%s)
rg (STRING): Name of the RAID group on which lost-write protection is disabled.
reason (STRING): A character string indicating the reason for disabling the lost-write protection for RAID I/O.
raid.rg.media_scrub.cksum_blk.err.bypass
Severity
NOTICE
For a zoned checksum aggregate this event is issued when background media scrub bypasses a media error on a checksum block.
Corrective Action
(None).
Syslog Message
Media error on checksum block bypassed for %s%s, block #%llu
owner (STRING): Owner of the affected aggregate.
disk_info (STRING): Formatted information of the disk object that contains the error.
blockNum (LONGINT): The physical block number containing the error.
raid.rg.media_scrub.done
Severity
NOTICE
This event is issued when media scrub has completed on a specific raid group.
Corrective Action
(None).
Syslog Message
%s%s: media scrub completed in %s
rg (STRING): The name of the raid group object that has completed media scrub
duration (STRING): The amount of time the media scrub required
raid.rg.media_scrub.media.err
Severity
NOTICE
This event is issued when a media_scrub i/o detects a medium error
Corrective Action
(None).
Syslog Message
Read error on %s%s, block #%llu during media_scrub
disk_info (STRING): The name of the disk object that contains the error.
raid.rg.media_scrub.media.errs
Severity
NOTICE
This message occurs when background media scrubbing detects a multi-disk media error on a stripe. Data ONTAP® will take appropriate recovery actions, as described in additional logged events.
Corrective Action
(None).
Syslog Message
Multiple checksum block read error on %s%s for blocks [#%llu - #%llu] during media_scrub.
rg (STRING): Name of the RAID group object that contains the multi-disk media error.
blockNum (LONGINT): First physical disk block number containing the error.
LblockNum (LONGINT): Last physical disk block number containing the error.
raid.rg.media_scrub.media.recommend.reassign.err
Severity
NOTICE
This event is issued when a background media scrub i/o detects a recommend reassign error
Corrective Action
(None).
Syslog Message
Block recommended for reassignment on %s%s, block #%llu during media_scrub
raid.rg.media_scrub.resume
Severity
NOTICE
This event is issued when media_scrub resumes on a specific raid group.
Corrective Action
(None).
Syslog Message
%s%s: resuming media scrub at stripe %llu (%d%% complete)
rg (STRING): The name of the raid group object that is resuming media_scrub
stripe (LONGINT): resuming at stripe.
percentage (INT): (None).
raid.rg.media_scrub.rewrite.chunk
Severity
INFORMATIONAL
This message occurs when background media scrub rewrites a chunk of blocks for ATA drives.
Corrective Action
(None).
Syslog Message
media_scrub rewriting chunk on %s%s, start block #%llu, count #%u.
disk_info (STRING): Information about the disk object, including disk name, path, shelf, bay, serial number, vendor, model, RPM , and carrier serial number.
blockNum (LONGINT): Physical block number at which the chunk starts.
count (INT): Number of blocks being rewritten.
shelf (STRING): Identifier of the shelf where the disk is located.
vendor (STRING): Name of the vendor of the disk.
model (STRING): Model name of the disk.
firmware_revision (STRING): Firmware revision number of the disk.
raid.rg.media_scrub.start
Severity
NOTICE
This event is issued when media_scrub has been initiated on a specific raid group.
Corrective Action
(None).
Syslog Message
%s%s: start media scrub
rg (STRING): The name of the raid group object that is initiating media_scrub
raid.rg.media_scrub.stopped
Severity
NOTICE
This event is issued when media scrub is stopped on specified raid group.
Corrective Action
(None).
Syslog Message
%s%s: media scrub stopped at stripe %llu after %s
rg (STRING): The name of the raid group object for which media scrub was stopped
stripe (LONGINT): stopped at stripe.
duration (STRING): The amount of time the media scrub has taken.
raid.rg.media_scrub.summary.media
Severity
NOTICE
This event is generated as a summary report for errors found during a media scrub.
Corrective Action
(None).
Syslog Message
(None).
errors (INT): The total number of media errors found
current (STRING): The current status
raid.rg.media_scrub.suspended
Severity
NOTICE
This event is issued when media scrub is suspended on specified raid group.
Corrective Action
(None).
Syslog Message
%s%s: media scrub suspended at stripe %llu after %s
rg (STRING): The name of the raid group object for which media scrub is suspended
stripe (LONGINT): suspended at stripe.
raid.rg.mirrorreaderr.fatal
Severity
NOTICE
This message occurs when the RAID mirror read error handling encounters an I/O error on the RAID group in the source plex. This is ultimately fatal error to the aggregate. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
Corrective Action
(None).
Syslog Message
%s: RAID mirror read error handling experienced fatal multi-disk error; failing RAID group.
rg (STRING): Name of the RAIDgroup that failed.
raid.rg.mirrorreaderr.nonfatal
Severity
NOTICE
This message occurs when the RAID mirror read error handling encounters an I/O error on a RAID group during a scrub, or lost write recovery operation. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
Corrective Action
(None).
Syslog Message
%s: RAID mirror read error handling experienced multi-disk error; continuing.
rg (STRING): Name of the RAID group that has a double error.
raid.rg.normal
Severity
NOTICE
This message occurs when a RAID group returns to normal after it was in one of the degraded states, after a resynchronization, or after it was in failed state.
Corrective Action
(None).
Syslog Message
%s: raid group %s is in normal state.
name (STRING): Relative path name of the raid group.
raid.rg.readerr.bad.file.block
Severity
EMERGENCY
This message occurs when a reconstructed file block is found out to be marked bad because it could not be recovered correctly earlier.
Corrective Action
Contact NetApp technical support.
Syslog Message
Reading bad block on %s %s%s, %s inode number %d, snapid %d, file block %llu, level %d.
vol_type (STRING): String indicating whether the file is contained in a flexible volume or aggregate.
owner (STRING): Owner of the aggregate.
vol (STRING): Name of the volume or aggregate
ino_type (STRING): The inode type
fileid (INT): File identifier
snapid (INT): Snapshot identifier
fileBlockNum (LONGINT): Block number in the file
level (INT): Inode indirect pointer level
raid.rg.readerr.block.fail
Severity
ERROR
This event is issued when a missing block could not be properly recovered because a read error that was detected on another disk in the group was bypassed.
Corrective Action
Ensure wafliron successfully completes. Wafliron will preserve the filesystem consistency.
Syslog Message
Block #%llu cannot be properly recovered on %s%s
blockNum (LONGINT): The physical block number that could not be recovered
disk_info (STRING): Formatted information of the disk to which the block belongs
raid.rg.readerr.recalc
Severity
NOTICE
This event is issued when a previously detected bad block is recalculated.
Corrective Action
(None).
Syslog Message
Recalculated bad block on %s%s, block #%llu
blockNum (LONGINT): The disk block number
raid.rg.readerr.recommend.failure
Severity
ERROR
This message occurs when a detected bad block is repeatly recalculated and written back to disk.
Corrective Action
Wait for the event message raid.disk.unload.done or raid.carrier.remove to be issued and then replace the carrier containing the failed disk. If the disk is contained in a single-disk carrier, raid.disk.unload.done will be issued immediately. Otherwise, wait for raid.carrier.remove which indicates the carrier has been fully prepared for removal.
Syslog Message
Disk failure due to repeated read errors on %s%s, block #%llu
owner (STRING): String indicating the owner of the affected volume.
disk_info (STRING): The name of the disk.
raid.rg.readerr.repair.cksum.computed
Severity
NOTICE
This message occurs when a previously detected bad block is repaired and the checksum of that recalculated block matches the computed checksum.
Corrective Action
(None).
Syslog Message
Recalc %s%s, block #%llu matches computed checksum
raid.rg.readerr.repair.cksum.error
Severity
NOTICE
This message occurs when a previously detected bad block is repaired and the checksum of that recalculated block does not match the stored and computed checksums.
Corrective Action
(None).
Syslog Message
Data recalculated from parity on %s%s; block #%llu does not match the stored and computed checksums.
owner (STRING): String indicating the owner of the affected aggregate.
disk_info (STRING): Information about the disk object, including disk name, path, shelf, bay, serial number, vendor, model, RPM, and carrier ID.
blockNum (LONGINT): Disk block number.
raid.rg.readerr.repair.cksum.stored
Severity
NOTICE
This message occurs when a previously detected bad block is repaired and the checksum of that recalculated block matches the stored checksum.
Corrective Action
(None).
Syslog Message
Recalc %s%s, block #%llu matches stored checksum
raid.rg.readerr.repair.data
Severity
NOTICE
This message occurs when fixing a single-disk media or checksum error on a data disk.
Corrective Action
(None).
Syslog Message
Fixing bad data on %s%s, disk block (DBN) %llu, aggregate block (VBN) %llu.
disk_info (STRING): Information about the disk object, including disk name, path, shelf, bay, serial number, vendor, model, rpm, and carrier serial number containing the block being rewritten.
vbn (LONGINT): Volume block number.
bay (STRING): Disk bay within the shelf where disk is located.
raid.rg.readerr.repair.data.dirty
Severity
NOTICE
This message occurs when fixing a single-disk media or checksum error on a data block that belongs to a dirty parity region.
Corrective Action
(None).
Syslog Message
(None).
raid.rg.readerr.repair.filebno
Severity
NOTICE
This event is issued when a previously detected bad block is repaired.
Corrective Action
(None).
Syslog Message
%s %s%s, %s inode number %d, snapid %d, treeid %d, uid %u, gid %u, file block %llu level %d
vol_type (STRING): Whether this error occurred in an aggregate, or a flexible volume.
owner (STRING): Owner of the affected volume or aggregate.
vol (STRING): The name of the volume or aggregate
fileid (INT): The file identifier
snapid (INT): The snapshot identifier
treeid (INT): The qtree identifier
uid (INT): The user id that owns the file
gid (INT): The group id that owns the file
bno (LONGINT): The block number in the file
level (INT): The level of the block within the file
raid.rg.readerr.repair.parity
Severity
NOTICE
This message occurs when fixing a single-disk media or checksum error on a parity disk.
Corrective Action
(None).
Syslog Message
Fixing bad parity on %s%s, block #%llu
disk_info (STRING): Formatted information of the disk containing the block being rewritten.
raid.rg.readerr.repair.parity.dirty
Severity
NOTICE
This message occurs when fixing a single-disk media or checksum error on a parity block that belongs to a dirty parity region.
Corrective Action
(None).
Syslog Message
(None).
raid.rg.readerr.wc.blkErr
Severity
EMERGENCY
This event occurs when a checksum error due to WAFL context mismatch is detected on a reconsructed block. This error indicates data loss and are caused by misbehaving disks.
Corrective Action
Start wafliron on the indicated volume or aggregate.
Syslog Message
Checksum error due to wafl context mismatch on %s %s%s, %s inode number %d, snapid %d, file block %llu, level %d, RBN %llu. Checksum context has FBN %llu, buftreeid %u, CP count %u, encrypted flag %d, key index %d, PVBN %lld.
blockNum (LONGINT): RAID Block Number (RBN) of the block
stored_fbn (LONGINT): Stored file block number in the checksum entry.
stored_buftreeid (INT): Stored buftree identifier in the checksum entry.
stored_cpcount (INT): Stored CP count in the checksum entry.
stored_encrypted_flag (INT): Stored encrypted flag in the checksum entry.
stored_key_index (INT): Stored encryption key index in the checksum entry.
pvbn (LONGINT): Physical Volume Block Number (PVBN) of the block
raid.rg.recon.bad.cksum.embd
Severity
NOTICE
This message occurs when the system detects an invalid checksum entry during reconstruction while the aggregate is in media error bypass mode. The embedded checksum computed over the checksum entry do not match, indicating the corruption of the checksum entry. The error is ignored.
Corrective Action
(None).
Syslog Message
Invalid checksum entry on %s%s, block #%llu during reconstruction while in media error bypass mode.
owner (STRING): Owner of the disk drive.
blockNum (LONGINT): Physical disk block number containing the error.
shelf (STRING): Disk shelf identifier where the disk drive is located.
bay (STRING): Disk bay within the disk shelf where disk drive is located.
vendor (STRING): Name of the disk drive vendor.
model (STRING): Model string of the disk drive.
firmware_revision (STRING): Firmware revision number of the disk drive.
serialno (STRING): Serial number of the disk drive.
disk_type (INT): Type of disk drive.
disk_rpm (STRING): Rotational speed of the disk drive, in RPM.
raid.rg.recon.bad.cksum.zero
Severity
NOTICE
This message occurs when the system detects an empty checksum entry during reconstruction while the aggregate is in media error bypass mode. The checksum entry is zeroed, but the corresponding block is not zeroed. The error is ignored.
Corrective Action
(None).
Syslog Message
Empty checksum entry for non-zeroed block on %s%s, block #%llu, during reconstruction while in media error bypass mode.
raid.rg.recons.aborted
Severity
NOTICE
This message occurs when reconstruction has been aborted on a specific raid group.
Corrective Action
(None).
Syslog Message
%s%s: reconstruction aborted at disk block %llu after %s
rg (STRING): Name of the raid group object that is aborted reconstruction.
blockNum (LONGINT): The physical block number reconstruction stopped
duration (STRING): The amount of time the reconstruction required
raid.rg.recons.bad.cksum
Severity
NOTICE
This event is issued when reconstruction detects a bad checksum on the stripe while the aggregate is in media error bypass mode.
Corrective Action
(None).
Syslog Message
Checksum mismatch on %s%s, block #%llu during reconstruction; assuming data is correct and fixing checksum
raid.rg.recons.bad.cksum.blk
Severity
NOTICE
This message occurs when reconstruction corrects a checksum block media error in an advanced_zoned checksums (azcs) RAID group on a stripe while in media error bypass mode. Data ONTAP® takes appropriate recovery actions. Other events describe those actions.
Corrective Action
(None).
Syslog Message
Checksum block read error on %s%s for blocks [#%llu - #%llu] during reconstruction; assuming data is correct and fixing checksum.
disk_info (STRING): Formatted information about the disk object that contains the error.
shelf (STRING): Disk Shelf identifier for the shelf on which the disk drive is located.
bay (STRING): Disk bay within the disk shelf on which the disk drive is located.
model (STRING): Model of the disk drive.
raid.rg.recons.bad.cksum.bno
Severity
NOTICE
This message occurs when the system detects a block number mismatch during reconstruction while the aggregate is in media error bypass mode. The expected Virtual Block Number (VBN)/Disk Block Number (DBN) is not the same as the stored VBN/DBN from the checksum entry, indicating that the block is read from the wrong location. The error is ignored.
Corrective Action
(None).
Syslog Message
Block number mismatch on %s%s: stored_dbn = %u, expected_dbn = %llu; stored_vbn = %llu, expected_vbn = %llu during reconstruction while in media error bypass mode.
stored_dbn (INT): Physical disk block number stored in the checksum entry.
expected_dbn (LONGINT): Expected physical disk block number.
stored_vbn (LONGINT): Volume block number stored in the checksum entry.
expected_vbn (LONGINT): Expected volume block number.
shelf (STRING): Disk Shelf identifier where the disk drive is located.
bay (STRING): Disk bay within the disk shelf where the disk drive is located.
raid.rg.recons.block.fail
Severity
ERROR
A block on the reconstructing disk can not be reconstructed because of a media error on another disk in the group. The block is zeroed and written to disk. If the block is allocated, data in that block is corrupted.
Corrective Action
Ensure wafliron successfully completes after this reconstruction is finished. Wafliron will preserve the filesystem consistency.
Syslog Message
Block #%llu can not be properly reconstructed on %s%s - the block will be zeroed
blockNum (LONGINT): The physical block number that could not be reconstructed
disk_info (STRING): Formatted information of the disk being reconstructed
raid.rg.recons.cantStart
Severity
ERROR
This event is issued when a RAID group is missing a disk but the reconstruction cannot be started.
Corrective Action
Usually, an appropriate spare disk should be installed. Sometimes, the quoted reason and presence of the appropriate spare disks can indicate a different problem.
Syslog Message
The reconstruction cannot start in RAID group %s%s: %s
reason (STRING): The reason the reconstruction cannot start
raid.rg.recons.cksum.bno
Severity
NOTICE
This message occurs when the system detects a block number mismatch during the RAID reconstruction process. The expected Virtual Block Number (VBN)/Disk Block Number (DBN) is not the same as the stored VBN/DBN from the checksum entry. This indicates that the block is read from the wrong location. Data ONTAP® takes appropriate recovery actions, as described in other logged events.
Corrective Action
(None).
Syslog Message
There was a block number mismatch on %s%s: stored_dbn = %u, expected_dbn = %llu; stored_vbn = %llu, expected_vbn = %llu during reconstruction.
raid.rg.recons.cksum.embed
Severity
NOTICE
This message occurs when the system detects an invalid checksum entry during the RAID reconstruction process. The embedded checksum computed over the checksum entry does not match the stored embedded checksum in the checksum entry, indicating the corruption of the checksum entry. Data ONTAP® takes appropriate recovery actions, as described in other logged events.
Corrective Action
(None).
Syslog Message
Invalid checksum entry on %s%s, block #%llu, during reconstruction.
disk_info (STRING): Information about the disk object, including disk name, path, shelf, bay, serial number, vendor, model, RPM, carrier ID, and site.
raid.rg.recons.cksum.err
Severity
NOTICE
This message occurs when the system detects a checksum error on the stripe during a RAID reconstruction operation. The checksum computed is not the same as the stored checksum. Data ONTAP® takes appropriate recovery actions, as described in additional logged events
Corrective Action
(None).
Syslog Message
Checksum error on %s%s, block #%llu during reconstruction.
blockNum (LONGINT): Physical block number containing the error.
raid.rg.recons.cksum.rderr
Severity
NOTICE
This message occurs when the system detects a checksum block media error in an advanced_zoned checksum’s (AZCS) RAID group during RAID reconstruction. Data ONTAP® takes appropriate recovery actions, as descibed in other logged events.
Corrective Action
(None).
Syslog Message
Checksum block read error on %s%s for blocks [#%llu - #%llu] during reconstruction.
owner (STRING): Owner of the disk.
model (STRING): Model of the disk.
raid.rg.recons.cksum.zero
Severity
NOTICE
This message occurs when the system detects an empty checksum entry during the RAID reconstruction process. The checksum entry is zeroed, but the corresponding block is not zeroed. Data ONTAP® takes appropriate recovery actions, as described in other logged events.
Corrective Action
(None).
Syslog Message
Empty checksum entry for non-zeroed block on %s%s, block #%llu, during reconstruction.
raid.rg.recons.deferred
Severity
NOTICE
This event is issued when the a raid group reconstruction has been deferred due to inadequate incore resources.
Corrective Action
(None).
Syslog Message
%s%s: reconstruction deferred (%s)
rg (STRING): The name of the raid group object that is unable to reconstruct
raid.rg.recons.deferred.ok
Severity
NOTICE
A previously deferred reconstruction is now ready to proceed.
Corrective Action
(None).
Syslog Message
%s%s: reconstruction previously deferred, now proceeding
rg (STRING): The name of the raid group object that is now able to reconstruct
raid.rg.recons.disabled
Severity
ERROR
This message occurs when a RAID group needs to start reconstruction, but reconstruction is disabled for the RAID group.
Corrective Action
Run the 'aggr recons enable' command for the RAID group.
Syslog Message
Reconstruction needs to be performed on RAID group %s%s, but reconstruction is disabled.
raid.rg.recons.done
Severity
NOTICE
This message occurs when reconstruction has been completed on a specific raid group.
Corrective Action
(None).
Syslog Message
%s%s: reconstruction for %s completed in %s.
disk (STRING): Name of the disk object for which reconstruction completed.
raid.rg.recons.info
Severity
NOTICE
This message occurs when a disk is selected for RAID group reconstruction.
Corrective Action
(None).
Syslog Message
Spare disk %s will be used to reconstruct one missing disk in RAID group %s%s.
disk (STRING): Name of the spare disk object that will be used for reconstruction.
raid.rg.recons.media.err.bypass
Severity
ERROR
This event is issued when reconstruction detects a read error but the error is bypassed. The block with read error is then zeroed and written to disk.
Corrective Action
Syslog Message
Media error bypass enabled, zeroing block %llu of Disk %s%s
blockNum (LONGINT): The physical block number that hit the read error
disk_info (STRING): Formatted information of the disk that hit the read error
raid.rg.recons.mismatch
Severity
ERROR
There was no available disk for reconstruction matching all parameters of an ideal replacement in the RAID group. Data ONTAP selected a disk with different interface speed or rpm, or from the opposite spare pool in a sync-mirror configuration.
Corrective Action
Wait for reconstruction to complete. Install an appropriate spare disk. Fail the mismatched disk using 'disk fail'. It will be copied to the new spare disk. After copying is done, use 'disk unfail' to unfail the mismatched disk and convert it to a spare.
Syslog Message
%s%s: matching disk not available for reconstruction; using disk %s %s
disk (STRING): The name of the disk used for reconstruction
detail (STRING): Description of disk mismatch; one or more of: from the opposite spare pool, with different rpm.
raid.rg.recons.missing
Severity
NOTICE
Information about disks missing from the RAID group.
Corrective Action
(None).
Syslog Message
RAID group %s%s is missing %d disk(s).
owner (STRING): The owner of the RAID group
rg (STRING): The name of the RAID group
missing (INT): Number of disks missing (1 or 2)
raid.rg.recons.multidisk
Severity
NOTICE
This event is issued when the reconstruction encounters an unrecoverable I/O error. We try to avoid panic in this case.
Corrective Action
(None).
Syslog Message
%s%s: reconstruction encountered a multi-disk error
rg (STRING): The name of the reconstructing raid group object.
raid.rg.recons.multidisk.bypass
Severity
NOTICE
Reconstruction can proceed and it will ignore media errors until completion.
Corrective Action
(None).
Syslog Message
%s%s: reconstruction will bypass media errors
raid.rg.recons.multidisk.fail
Severity
ALERT
The recovery procedure for a media error during reconstruction has failed. The filer will panic to allow recovery after reboot. After reboot, the affected volume will be restricted and marked wafl inconsistent.
Corrective Action
Start wafliron to bring the affected volume online.
Syslog Message
%s%s: failed to recover from a multi-disk error
raid.rg.recons.resume
Severity
NOTICE
This message occurs when reconstruction has been resumed on a specific raid group.
Corrective Action
(None).
Syslog Message
%s%s: resuming reconstruction, using disk %s (disk block %llu, %d%% complete)
rg (STRING): Name of the raid group object that is initiating reconstruction.
disk (STRING): Name of the disk object that is the reconstruction target.
blockNum (LONGINT): The physical block number on which reconstruction is resuming.
percent (INT): The percentage of reconstruction already complete.
raid.rg.recons.start
Severity
NOTICE
This message occurs when reconstruction has been initiated on a specific raid group.
Corrective Action
(None).
Syslog Message
%s%s: starting reconstruction, using disk %s, disk block %llu.
startBlockNum (LONGINT): The physical block number on which reconstruction is starting.
raid.rg.recons.suspended
Severity
NOTICE
This message occurs when reconstruction is suspended on a specific RAID group that is yielding to higher priority reconstruction.
Corrective Action
(None).
Syslog Message
%s%s: reconstruction suspended at disk block %llu after %s, yielding to higher priority reconstruction
rg (STRING): Name of the RAID group object that suspended reconstruction.
blockNum (LONGINT): Physical disk block number where reconstruction stopped.
duration (STRING): Amount of time spent on reconstruction before it was suspended.
raid.rg.recons.throttle
Severity
NOTICE
This event is issued when we start throttling the number of messages that reconstruction generates due to an overwhelming number of messages that are being generated.
Corrective Action
(None).
Syslog Message
Too many bad checksum messages; will emit message once every %d seconds, dropping others.
interval (INT): The interval at which we will generate messages
raid.rg.reparity.aborted
Severity
NOTICE
This event is issued when parity recomputation has been aborted on a specific raid group.
Corrective Action
(None).
Syslog Message
%s: parity recomputation aborted after %s
rg (STRING): The name of the raid group object that is completed parity recomputation
duration (STRING): The amount of time the reparity ran
raid.rg.reparity.bad.cksum
Severity
NOTICE
This message occurs when the computed checksum of a block does not match the stored checksum during a reparity operation.
Corrective Action
(None).
Syslog Message
Checksum mismatch on %s%s, block #%llu during parity recomputation; data is assumed to be correct and fixing checksum.
raid.rg.reparity.cksum.bno
Severity
NOTICE
This message occurs when the system detects a block number mismatch during parity recomputation. The expected Virtual Block Number (VBN)/Disk Block Number (DBN) is not the same as the stored VBN/DBN from the checksum entry indicating that the block is read from the wrong location. Data ONTAP® makes appropriate recovery actions. Other events describe those actions.
Corrective Action
(None).
Syslog Message
Block number mismatch on %s%s: stored_dbn = %u, expected_dbn = %llu; stored_vbn = %llu, expected_vbn = %llu during parity recomputation.
raid.rg.reparity.cksum.embed
Severity
NOTICE
This message occurs when the system detects an invalid checksum entry during parity recomputation. The embedded checksum computed over the checksum entry do not match, indicating the corruption of the checksum entry. Data ONTAP® makes appropriate recovery actions. Other events describe those actions.
Corrective Action
(None).
Syslog Message
Invalid checksum entry on %s%s, block #%llu, during parity recomputation.
raid.rg.reparity.cksum.rderr
Severity
NOTICE
This message occurs when parity recomputation detects a checksum block media error in an advanced_zoned checksum’s (azcs) RAID group. Data ONTAP® takes appropriate recovery actions. Other events describe those actions.
Corrective Action
(None).
Syslog Message
Checksum block read error on %s%s for blocks [#%llu - #%llu] during parity recomputation.
shelf (STRING): Disk shelf identifier for the disk shelf on which the disk drive is located.
raid.rg.reparity.cksum.zero
Severity
NOTICE
This message occurs when the system detects an empty checksum entry during parity recomputation. The checksum entry is zeroed, but the corresponding block is not zeroed. Data ONTAP&
